How to disable UAC for select programs
Discussion in 'Windows OS and Software' started by Joyscant1980, Aug 21, 2008.
  1. Joyscant1980
    Joyscant1980 Notebook Consultant
  2. houstoned
    houstoned Yoga Pants Connoisseur.
    check out this thread for all yur vista tweaks and customizations.
  3. ScuderiaConchiglia
    ScuderiaConchiglia NBR Vaio Team Curmudgeon
    What does that have to do with disabling UAC for a single process? I am a contributor to the thread you mentioned, but don't see the relevance to this thread.
    Gary
  4. crash
    crash NBR Assassin Super Moderator
    Wow, that's a lot of work to disable UAC for just one program. Fortunately, I almost never get a UAC prompt unless I'm installing something or changing some settings in the control panel.
    I believe houstoned intention was either
    1. Indicate that this particular fix/tweak was already in that thread (which it is NOT)
    -or-
    2. Indicate that this should be posted in that thread (which I don't think it should be for multiple reasons)
  5. ScuderiaConchiglia
    Yep, it is a bit of a pain in the rear. But I did do it for one program many months ago. But don't remember which one. It might have been SpeedFan, which I run as part of my startup group so I have temps in the notification area (aka system tray). It always prompted for permissions, so I used the mentioned "trick".
    Gary
  6. crash
    Can't you use task scheduler to allow the program to start up with elevated permissions without prompting?
  7. swarmer
    swarmer beep beep
  8. crash
    Regarding that method... Can you use task scheduler to make the task automatically run on startup, or do you have to manually run it (even if from a simple shortcut) each time?
  9. swarmer
    swarmer beep beep
    There's an option you can select in Task Scheduler if you want it to run automatically at startup (or at login).
  10. crash
    Ok that's what I thought. Thanks for clearing that up (I'm on XP at work right now with no access to Vista, so I couldn't check myself).
