how to delete LAME mp3 codec
Discussion in 'Windows OS and Software' started by dwd, Jan 31, 2009.
  1. dwd
    dwd Notebook Consultant
    does anyone know how to remove lame mp3 codec from your computer?
  2. elijahRW
    elijahRW Notebook Deity
    All you should need to do is go to your Control Panel / Multimedia / Devices tab and look under "Audio Compression Codecs". All your installed codecs will be listed there. You can re-prioritize them, disable certains ones if you wish, or remove individual codecs.
  3. DetlevCM
    DetlevCM Notebook Nobel Laureate
    As far as I'm aware the lame codec is just a signle dll file - i.e. just remove the file.
    But may I ask why you want to get rid of it?
  4. dwd
    I'm running vista. I can't see any multimedia tab.
    edit: i want to remove it because it is messing up another program that i am using and i don't really know what it does either
  5. DetlevCM
    Ok, search for lame.dll - you should find a file.
    lame is jus tone of several MP3 codes/decoders
  6. Duct Tape Dude
    Duct Tape Dude Duct Tape Dude
    Yeah LAME is just a .dll, it's not used as a codec but rather as an encoder.
  7. dwd
    thanks for the help
