How to control Ur laptop fan speed
Discussion in 'Gaming (Software and Graphics Cards)' started by allegroyell, Jun 15, 2008.
  1. allegroyell
    allegroyell Newbie
    Hi
    I'v been seeking all over and couldnt find the resolution.
    Does any body know soft to regulate fan speed independently??
    My laptop is keeking switching off while playing any powerfull games.
    thx
  2. lunateck
    lunateck Bananaed
    Issit a new laptop?
    Would be nice if you provide specifications and stuff. At best, get a laptop cooler.
  3. flipfire
    flipfire Moderately Boss
    Only a small amount of notebooks are able to tweak the fan settings. All other notebooks fan algorithm is coded into the BIOS.
    You have a overheating problem, not a fan problem. Doesnt your fans run of full blast when playing games?
  4. allegroyell
    allegroyell Newbie
    iv tried speedfan sof, but it didn work,
    during playing it doesnt seem like working with full blast its rather not
  5. eleron911
    eleron911 HighSpeedFreak
    You can try Speedfan, nvidia ntune, riva tuner or I8kfanGUI .
    But as Flip said,only a handful of laptops have controllable fan speeds...
  6. TheRealFireblade
    TheRealFireblade Notebook Consultant
    What make/model laptop is it?
    It's intended for Dell laptops, but as mentioned above... I8kfanGUI might be worth trying anyway, even if yours isn't a Dell?
    Heed the warnings on the product page though!
    Notebook Hardware Control also allows for fan control - on some laptops.
    I don't know which laptops they are though, 'coz they're not mentioned on the product homepage?
  7. ronkotus
    ronkotus Notebook Evangelist
    Most, if not all laptops can have their fan controlled by NHC, since atleast to my knowledge, all laptops have ACPI. But it isn't simple as that. You need to know something about programming with C#. More info on this page: http://www.pbus-167.com/nhc/nhc_advanced.htm#anchor_acpi_programming
    Or, if your laptop is listed on this page, you can get ACPI files made by someone else. Note however, that you use those files at your own risk. Read carefully the information provided by their authors before applying them to NHC.
  8. eleron911
    I have a hard time believing manufacturers would give the user fan control... but still, some have done it ,while keeping a safety margin for it.
    If you have a Dell you just may be lucky...
