How to connect two laptops?
Discussion in 'Networking and Wireless' started by fsljff, Jan 14, 2006.
  1. fsljff
    fsljff Notebook Enthusiast
    I am having two laptops right now. What I want to do with them is that I have many video file on laptop A, and I want to watch them on laptop B, so what's the way to get access to these files on A from B and fast enough to watch video? And I don't want to copy them over from A to B.
    Thanks.
  2. nickspohn
    nickspohn iPhone NBR Reviewer
    It's been posted many times:
    http://forum.notebookreview.com/showthread.php?t=29726&highlight=Ad-hoc
    To transfer them wirelessly, you need 2 wireless cards. If you don't have wireless cards in each computer, you need to purchase a Ethernet Crossover cable as no regular ethernet cable will work.
    What do you mean by not copying the videos on to each computer? The only way im sure of is you need to transfer them over to laptop B. Which means the file from laptop A, will be on laptop B.
  3. ZaZ
    A router is another option.
  4. fsljff
    Ok, so now I'm trying to connection with a router. My laptop A is connected through a cable, laptop B is connected through the wireless. I ran both the networking setup, but only A can have access to B, and B somehow cannot get access to A, it said I need to permission. So how to gonna do it?
    Thanks
  5. Chutsman
    Chutsman Notebook Evangelist
    That's a lot of "trouble" to go through just to NOT have the video file on laptop B.
    Would putting the files on a DVD or external usb drive be acceptable?
  6. nickspohn
    Disable all your firewalls for computer A and B. (Make sure the Windows one is disabled), and any other firewalls that you have enabled.
  7. fsljff
    Did that....but still not working......:(
  8. ZaZ
    Can you see the other laptop on the network?
  9. fsljff
    yea, A can see both B and itself and access B, but B can just see both A and itself, not having access to A
  10. ZaZ
    Did you share the drive you want access to? Perhaps turning off simple file sharing will help.
