How to connect m15x to my T.V. ???
Discussion in 'Alienware' started by Andrewkm, Dec 21, 2008.
  1. Andrewkm
    Andrewkm Notebook Guru
    How do I connect my alienware m15x to a tv so that I can see the games that im playing, basically whatever is showing on the alienware screen will show on the television?
    I know I can do it with my desktop and the 8800gtx i have (Desktop version) ... i just connect some cables and stuff and it works.....
    How does it work with the m15x?
    Or do i have to buy something specially made for the m15x?
  2. whizzo
    whizzo Notebook Prophet
    you will need a TV that has a HDMI or DVI port. if you have either of these, go to your local electronics shop and pick up a HDMI cable, and if necessary a HDMI-DVI adapter. then, simply connect the TV to your m15x via the HDMI port located on the right side of your laptop.
  3. ChutneyRemix
    ChutneyRemix Notebook Geek
    hit fn+F6 until the desired effect takes place and then go to "sound" in settings and under playback tab enable realtek digital output nad disable the speakers, and it should work with both vid and sound.
    to see the disabled devices, right click on an open space in the sound playbakc tab and check show disabled devices.
    vice versa to go back to your mobile set.
  4. Mystik
    Mystik Notebook Deity
    or you could enable dualview or twinview via the nVIDIA software.
    note: you can't use HDMI on integrated graphics.
    if you're confused by this, then the problem is probably somewhere in the reigon of PEBKAC....
