How to completely disable 'readyboot'? (Not readyboost)
Discussion in 'Windows OS and Software' started by ari_m, Dec 13, 2007.
  1. ari_m
    ari_m Notebook Consultant
  2. notyou
    notyou Notebook Deity
  3. ari_m
  4. notyou
    You're right, it doesn't talk about readyboot but it's very likely the same thing as prefetching. I haven't tried the tool yet but I'll do it for you and post what happens.
    EDIT: just ran the installer and it lets you customize what you want to disable/enable so you could just disable the prefetching.
  5. ari_m
    Terrific! I'll try it when I get home - thanks very much!
    :D
  6. AKAJohnDoe
    AKAJohnDoe Mime with Tourette's
    I have turned off the READYBOOST service; however, under C:\Windows\Prefetch\ReadyBoot\ there is still a READYBOOT.ETL file that is 17.920KB, gets recreated if deleted, and when copied over to a .txt file and viewed appears to be a list of the names of virtually every file on the PC.
    Any thoughts on how to kill READYBOOT, preferrably without also slaying PreFetch and SuperFetch?
  7. qhn
    qhn Notebook User
    short from moving away from Vista (or taking chance with blasting registry to kil the eCache), i do not see how one can take out readyboot service. It is part of vista kernel!
    http://technet.microsoft.com/en-us/magazine/cc162480.aspx
    cheers ...
  8. atbnet
    atbnet Notebook Prophet
    Whats the benefit of disabling Superfetch?
  9. AKAJohnDoe
    There is no benefit to turning off SuperFetch. Nor to turning off Fetch, for that matter. But if you want to see for yourself, Here Is How.
  10. AKAJohnDoe
    I turned the ReadyBoost service back on. There is an application program, ReadyBoo*, running as shown by TaskManager, as before post-boot. I'll have to wait awhile before I'll know of that huge ReadyBoot.etl file is recreated or not.
    Update: It appears to not create the .etl file, so the ReadyBoost service stays enabled.
