How to clean matte surfaces
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by whyamihere, Feb 4, 2012.
  1. whyamihere
    whyamihere Notebook Enthusiast
    Hey, I just got a Lenovo thinkpad edge e420 and I believe it has a matte top cover/palm rests etc. It has quite a rubbery feel to it which is why I am not sure how to clean it, How do I clean it? and get dust off it?
    Also how do i get dust out from in between keys (other than a compressed air can) ?
    and I was actually looking at a zagg invisible shield for the cover and palm rests. Is it worth it? do the matte surfaces scratch/wear easily? If anyone has one or knows, is the skin very noticeable? and how does it feel once the skin is on?
  2. jotm
    jotm Notebook Evangelist
    For matte surfaces, I just use a microfiber cloth/towel - it works perfectly. It also works for the display and keyboard. For hard to reach places, I use a simple *soft* paint brush to get the dust out (works for the heatsink and fan, too, sometimes better than compressed air).
    Hope that helps...
  3. baii
    baii Sone
    Just a quick question regarding cleaning monitor, would bounty + rubbing alcohol kill my screen? had been doing tat for awhile...
  4. jotm
    Not if its glass, but I think wiping it with alcohol will make a display blurry over time...
  5. Moomagic
    Moomagic Newbie
    How is a matte screen different than a glossy screen other than appearance? Does one screen show dead pixels more than the other? Are the graphics clearer on one than the other? Is one easier on the eyes for extended use? I'm in the process of buying a new laptop, and have the option of going glossy or matte.
  6. Geekz
    Geekz Notebook Deity
    the zagg invisi shield would be great for the palm rest and would be easier to clean as well.
    however not sure how much the cost would for the customization for your laptop, also it does turn to a yellowish brown color over time but does give great protection for scratches and dirt.
  7. JOSEA
    JOSEA NONE
    Generally Matte is glare resistant, especially when used outside compared to Glossy. If you post the model you are considering we can give a better answer.
    http://forum.notebookreview.com/what-notebook-should-i-buy/32747-glossy-vs-matte.html
  8. Ferrari353
    Ferrari353 Notebook Evangelist
    You could take the keys off to get junk out, but compressed air is usually the best option.
  9. dempar
    dempar Notebook Enthusiast
    Microfiber cloths all the way.
