How to automatically under-volt in XTU without opening it
Discussion in '2015+ Alienware 13 / 15 / 17' started by ThatOldGuy, Mar 3, 2017.
  1. RanCorX2
    RanCorX2 Notebook Evangelist
    what about getting a profile to auto load at windows logon? how does one do that? like a profile that only overclocks turbo speed?
  2. RoryH
    RoryH Notebook Enthusiast
    Just install an older version of XTU. I uninstalled the latest one and downloaded 6.2.0.19. It automatically loads the profile within a minute after login. They removed the feature in the newer ones for some reason.
    etern4l and hmscott like this.
  3. Ultra Male
    Ultra Male Super Tweaker
    Thanks for the guide
    Vasudev and Papusan like this.
  4. hexaae
    hexaae Notebook Consultant
    Please, can you check in Task Scheduler where is the task that loads the profile and what does it do exactly?
    My goal would be to use latest XTU since I have a i7-8750H, and re-enable profile loading with undervolt on startup always working, even after hibernation or full shutdown...
  5. RoryH
    Sorry mate, nothing in the task scheduler that points to Intel xtu or similar, I checked.
  6. 6.|THE|1|BOSS|.9
    6.|THE|1|BOSS|.9 Notebook Evangelist
    Thank you!, this one helped me alot! :) rep+ given ;)
    Vasudev likes this.
  7. sazistas
    sazistas Notebook Consultant
    I tried your program, I entered my profile but it doesn't work, when I open the xtu i get an error message that the profile didn't applied. Also during the startup, a PowerShell window shows up for a second and then disappear. How can I uninstall your program?
  8. shisui
    shisui Notebook Enthusiast
    You should try throttlestop first, see if it can meet your needs.
    I am not sure which script you are using, for the first one, run `remove...` with admin, for the second, just run again.
    The 2nd one is better if u are using win10.
    If you can't remove it totally, you should check out your `task scheduler`.
    It is very clean and won't break your pc.
  9. bbot3k
    bbot3k Notebook Consultant
    I found ThrottleStop to not misbehave in terms of automatically undervolting compared to setting up XTU.
