How to automatically under-volt in XTU without opening it
Discussion in '2015+ Alienware 13 / 15 / 17' started by ThatOldGuy, Mar 3, 2017.
  1. AlexanderKim
    AlexanderKim Notebook Guru
    I still have flashing powershell window. Something is wrong. Win 10 (1803)
  2. shisui
    shisui Notebook Enthusiast
    Thanks a lot, I made a program to auto apply these settings
    Run with admin, then input values
    Every time you want to set new values, remember to remove last settings, also run with admin.
    No need to use this one anymore, use the program I uploaded below
    or click
    Ultra Male and hmscott like this.
  3. RoryH
    RoryH Notebook Enthusiast
    I hadn't used Intel XTU in ages until just recently, but I remember when I got my G750 in 2013 and was experimenting with undervolting I definitely remember that XTU used to automatically apply the settings after a boot up. It wasn't immediately but after a few minutes when I would check CPU-Z, I would see the core multipliers overclocked.
    Can anyone confirm that this feature has been removed from newer/current versions of XTU?
    hmscott likes this.
  4. RoryH
    Hi, I opened the app and noticed it asks for core voltage. Currently I am only using core voltage offset, and cache voltage offset, as well as increased multipliers. Does the exe file have those features? What command would I enter to skip the core voltage question if so.
    Cheers!
  5. shisui
    The first setting under-volt is to set voltage offset, input "-100" means reduce the voltage of 100mv.
    Sorry, only four options :
    1. under-volt
    2. long boost watt
    3. short boost watt
    4. short boost time
    For now, I only found those settings' command.
    If you don't want it working, type default value, for under-volt is 0.
    Of course, run remove with admin everytime you want to change it.
    First time to write ps scripts, sorry:(
    I may improve it when I have time.
    A better way to achieve this is to auto apply xtu profile.
  6. RoryH
    Thanks for your reply, no problem.
    I actually uninstalled the latest XTU version and just went back to version 6.2.0.19 (as someone mentioned earlier in the thread) and now its working again and automatically applying the underclock without any any powershell or messing around :)
    So I think they removed the automatic applying from newer versions, which is a shame.
    hmscott likes this.
  7. shisui
    Hi, I made a script can auto apply xtu profile. Easy and simple.
    All you need to do is to input your xtu profile name.
    6.|THE|1|BOSS|.9 and RoryH like this.
  8. Djadit
    Djadit Notebook Evangelist
    What if im undervolt i must overclock to? Cause i have fps drop if im undervolt without overclock it
    Sent from my SM-G965F using Tapatalk
  9. hmscott
    So do both :)
    There are lots of articles and forum threads about this, you can find what you need through XTU docs, forums, and google:
    https://www.google.com/search?q=intel+xtu+command+line+options
    Djadit likes this.
  10. Djadit
    hmscott likes this.
