How to automatically under-volt in XTU without opening it
Discussion in '2015+ Alienware 13 / 15 / 17' started by ThatOldGuy, Mar 3, 2017.
  1. bennycooly
    bennycooly Notebook Enthusiast
    Hey, thanks for the useful thread! I made a few changes to the script so that it waits for the undervolts to apply rather than calling sleep:
    $xtu = "C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client\XTUCli.exe"
    $status = get-service -name "XTU3SERVICE" | Select-Object {$_.status} | format-wide
    if ($status -ne "Running") { start-service -name "XTU3SERVICE"}
    $procs = $( Start-Process -FilePath $xtu -PassThru -WindowStyle Hidden -ArgumentList "-t", "-id", "34", "-v", "-100";
    Start-Process -FilePath $xtu -PassThru -WindowStyle Hidden -ArgumentList "-t", "-id", "83", "-v", "-100")
    $procs | Wait-Process
    exit
    This way, we don't need to wait for the entire 4 seconds. Then, in Task Scheduler, simply choose to execute PowerShell.exe and then with the following arguments:
    -WindowStyle Hidden PATH_TO_SCRIPT\xtu.ps1
    The -WindowStyle Hidden basically runs the script without opening a window at all. I checked with reboots, shutdown, and wake from sleep, and it looks like these settings will stick.
    Hope this helps!
  2. Matthias Mahler
    Matthias Mahler Newbie
    Hey guys.
    First of all big thanks for the informations to auto apply the intel XTU Setting.
    I want to auto apply this settings to undervolt my 4790K (HTPC):
    Which IDs is for the setting:
    Turbo Boost Max = "78 W"
    Processor Current Limit: = "78 A"
    Turbo Boost Short Power Max ="85 W"
    CPU VCore Offset = "- 0.950"
    Turbo All Cores
    Big thanks for help.
    hmscott likes this.
  3. Matthias Mahler
    This helped me guys to load your Profile of XTU!: https://gist.github.com/michael-baker/f3962ba8d21ebd680b8e76c20eaa48c1
    01. Start Intel XTU & set & apply your own Profile.
    02. Start cmd.exe and write "cd C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility"
    03. Write into cmd.exe "XtuCLI.exe -i all"
    04. After that, go to path (windows explorer) "C:\XTU_xmlFiles" and open the file "Tuning.txt".
    05. Now you see all ids for your custom profile and take the informations for your own script.
    Have fun & good luck ^^
    hmscott and Mr. Fox like this.
  4. Mr. Fox
    Thanks for sharing. Welcome to the community.
    hmscott and Matthias Mahler like this.
  5. Matthias Mahler
    hmscott likes this.
  6. Matthias Mahler
    Thank you for the welcome and this great community and the great and also the professional reviews!
  7. 6.|THE|1|BOSS|.9
    6.|THE|1|BOSS|.9 Notebook Evangelist
    Seems like to share this ps1 code here in case someone wanted to play with BCLK for 6700HQ as TS doesn't provide an option to change BCLK ..only XTU provide this option :) simply copy it on a notepad and then rename the extension file from .txt to .ps1 :)
    Here :) :-
    if ($status -ne "Running") { restart-service -name "XTU3SERVICE"}
    & 'C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client\XTUCli.exe' -t -id 34 -v -155
    & 'C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client\XTUCli.exe' -t -id 1 -v 102.700
    & 'C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client\XTUCli.exe' -t -id 79 -v -155
    & 'C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Client\XTUCli.exe' -t -id 59 -v 11,5
    sleep 2
    stop-service -name "XTU3SERVICE"
    sleep 4
    stop-process -id $PID -force
    Thanks to @ThatOldGuy for providing this amazing idea :)
    Vasudev, ThatOldGuy and hmscott like this.
  8. Mer-One S. Bolinto Jr.
    Mer-One S. Bolinto Jr. Newbie
    Hello sir. Im sorry to ask. But how do you exactly do step 4?
  9. Sen7inel
    Sen7inel Notebook Consultant
    1. Thank you for this powershell script!
    2. In order for this to work I had to Set-ExecutionPolicy Unrestricted in Powershell, otherwise the .ps1 woudn't execute through Task Scheduler.
    3. I had to stick my .ps1 in a path containing folders named without spaces. Tried single and double quotes around my path, no dice.
    Hopefully this helps someone
  10. zjones22
    zjones22 Newbie
    Cant i just go into XTU and go into pairing and automatically have it sync with powershell.exe and then have XTU open when computer starts up in task manager, makes it easier. Would this possibly be bad for the computer, so far i have found luck, only time i didnt is when i went to update to 1803 for windows. but i just did it all over again
    hmscott likes this.
