How do you connect a PC to a laptop using the laptop as a monitor?
Discussion in 'Dell' started by trevorman1, Sep 16, 2007.
  1. trevorman1
    trevorman1 Newbie
    How do you connect a PC to a laptop using the laptop as a monitor? I don't know if this is possible, or how to attempt it. The laptop is a new dell 1520.
    I want to do this because I have an xbox 360 with a VGA Adapter I use on a flatscreen monitor at home. Can't bring the monitor to school with me. I do have the xbox with a VGA adapter.
    - Thanks for the help.
    Trevor
  2. Khris
    Khris Yes I am better than you!
    Uhm.......What?!
    If I understand correctly, you want to use your Xbox and have it displayed on your laptop?
    You'll need some sort of video capture card. Generally they only accept S-Video or Composite input.
  3. Devedander
    Devedander Notebook Evangelist
    Most laptops do not have a video in option by default.
    Your best bet is to get some kind of video input card as mentioned above, but in order to get the higher resolutions (above 480p) that you would almost certianly want with a 360 you will probably have to shell out $$$ as most consumer leve input setups are based aroudn Svideo or Composite inputs neither of which carry over 480p.
  4. nizzy1115
    nizzy1115 Notebook Prophet
    it would be cheaper to ebay a 17-19" lcd tv ;)
  5. billcsho
    billcsho Notebook Deity
    Remote desktop.
  6. boxcar_racer821
    boxcar_racer821 Notebook Consultant
    get a new lcd screen...right now (as long as you dont demand HD) they are dirt cheap. Seriously, check some places out online and you can get a good one for like $200 or less.
  7. The Goalkeeper
    The Goalkeeper Notebook Guru
    compusa has the acer 22" going for $200 right now. i'm using it and it's wonderful!
  8. n19htmare
    n19htmare Notebook Evangelist
