How do I reset my Macbook pro to default factory setting?
Discussion in 'Apple and Mac OS X' started by Joeycyw, Aug 14, 2006.
  1. Joeycyw
    Joeycyw Notebook Consultant
    I'm going to sell my macbook pro on ebay. I want to make sure none of my user settings, files or password are passed to the next user. Is there a way to restore the entire MacOSX back to factory state?
    Thanks in advance
  2. tuurtje97
    tuurtje97 Notebook Guru
    just format your harddisk
  3. zadillo
    zadillo Notebook Virtuoso
    Yes, you can use the original restore CD's that came with your Mac. They will give you an option to completely reformat the HD and reinstall OS X and the bundled applications, bringing it back to its factory state.
  4. Joeycyw
    Thanks for the help guys!
  5. jeme
    jeme Notebook Evangelist
    If you don't mind me asking why are you selling your MBP?
