How do i properly clean Thermal Grizzly Condunaut?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Al_Jourgensen, Feb 9, 2018.
  1. Papusan
    Then post pictures when first application is done (disassemble and check spread - before final application).
    Al_Jourgensen likes this.
  2. TheReciever
    TheReciever D! For Dragon!
    That just means you have poor contact at the very least
  3. jclausius
    jclausius Notebook Virtuoso
    In regards to your CPU, perhaps you could get some ideas from this video -
    But instead of lapping the CPU, you'll be lapping the heat sink.
  4. hmscott
    @GENOCID - this kind of proactive manipulation of the heatsink/heatplate is what I was talking about, fiddling / wiggling to get better contact patch across CPU when loose, and pressing down on the cooling plate / assembly before screwing it down. Give an assist to the screws pulling it down.
    Good work Al :)
  5. Al_Jourgensen
    Al_Jourgensen Notebook Consultant
    Thank you all for your replys, I'm enlightened now, I only have one problem, where do I buy those squares? Or something similar? The sand paper is fine to get, but the block I can't find it; as I told you, block here means brick and I'm googling to try to find one but no luck, gonna try harder and as soon I have something I'll feedback right away.
    Thank you very much for your help once again
    Update: i found this https://m.ebay.co.uk/itm/COPPER-Sheet-Plate-8-Different-Thicknesses-23-Popular-Sizes-/302204943332 I don't know if this are the blocks.
    What thickness should they have?
    hmscott likes this.
  6. Papusan
    You can use what you have. Small and flat enough and fits in you hand. Or search after similar like this www.performance-pcs.com-premium-heatsink-lapping-kit
    Ashtrix, hmscott and Al_Jourgensen like this.
  7. Al_Jourgensen
    hmscott and Papusan like this.
