1. Due to some system maintenance the forum will be unavailable for about 15 minutes starting at 4 p.m. ET. We'll remove this notice when the work is complete - sorry for any inconvenience!
    Dismiss Notice
how do i power cycle the battery?
Discussion in 'Alienware 14 and M14x' started by Sefal, Jul 31, 2012.
  1. Sefal
    Sefal Notebook Enthusiast
    i just got my m14xr2 and i tried power cycling it. charging the battery to full and then letting it go down. however at 7% it hibernates. do i need to let it be complety discharged at 0% and then charge it up?
    wont it do harm to the computer to shutdown suddenly?
  2. laz91
    laz91 Notebook Evangelist
    Refer here for how to disable hibernation. Haha it will be fine - little difference to it shutting down normally. Refer to my thread here for more info on power cycling (from Dell reps)
  3. Recce
    Recce Notebook Enthusiast
    Don't worry on cycling it to completely empty - down to 7% should be close enough. Heat damages battery life more than a lack of proper cycling, so if anything I would be more cognizant of that.
  4. Sefal
    thank you guys. i just did my 1st power cycle. 2 more to go!
