how do i override device ids in nvflash.
Discussion in 'Gaming (Software and Graphics Cards)' started by dellienware owner, Jan 31, 2020.
  1. dellienware owner
    dellienware owner Notebook Evangelist
    somehow i flashed a 1be1 bios onto a 1ba1 card. I have tried several versions of nvflash. i can over ride the sub id but not the device id. When trying to flash using -6 -o it tells me that i cannot preform this actrion on the eeprom in write mode.
    Any suggestions.
    flashing a 1070m black pcb card.
  2. Mr. Fox
    You may have to use an SPI programmer. Software flashing became more restrictive with Pascal and even more so with Turing.
    triturbo likes this.
  3. dellienware owner
    Any advice on how to keep from using an spi? Could i edit the registry to have the card say its a 1ba1, then flash the vbios?
    if so where in the registry would i change the values?
  4. Mr. Fox
    Editing the registry will not change information that NVFLASH pulls directly from the hardware. NVFLASH doesn't read from the Windows registry as far as I know. If you haven't already, you might want to investigate if there is a DOS version. If you get the same result, that will be absolute confirmation that the registry has nothing to do with NVFLASH.
  5. dellienware owner
    how about using a hex editior then flashing the file?
    Mr. Fox likes this.
  6. Mr. Fox
    If you modify the file it will not flash on Turing or Pascal GPUs because of modifications breaking the signature. You would have to be able to "sign" the firmware as NVIDIA. The only way to flash modded firmware where signature enforcement is required is by using an SPI programmer.
    You should really consider SPI flashing. The programmers, alligator clips and 1.8V adapters are not expensive, and it eliminates all of the firmware signing idiocy. If you flash firmware that bricks the GPU, you force the original firmware onto the chip with the programmer. No nonsense and you'll never need to care about whether or not NVFLASH works, or worry about bricking the GPU with a bad flash or wrong firmware.
    You can do the same thing with the motherboard's BIOS (all of which require now a valid signature for flashing). Now that I am used to using an SPI "sledgehammer" I actually prefer that approach. The manufacturer no longer has any say in what firmware I use and the liberty they choose to take as a Nazi control freak no longer affects me. It's none of there business anyhow--never has been, and never will be--but I love the liberty of doing whatever I want to do without their approval.
    The exception is the systems with BIOS Guard. You cannot flash the firmware on the motherboards that use that Gestapo filth because the BIOS is protected by firmware cancer on the PCH chip.
  7. dellienware owner
    bought a programmer, do you have any helpful tips on for a first time user?
  8. dellienware owner
    May I get tips from someone on how to Spi flash.
    Will tip for the usage of your time.
  9. Hirosake
    Hirosake Guest
    Im in same boat (I think) ...1BE1 on top of a 1BA1.....why so hard to flash back again!?!?!...it sucks but anyway
    I have a programmer on way..I hope its right one. I saw a few youtube things but....not exactly clear.
    Anyone have tips to reflash a MXM video card?...I can see the bios chip but can not read what it is. (msi 1070)
    Thank you
  10. Hirosake
    Hirosake Guest
    Might have to just wing it
    Well Dellien....from youtube i see we need to know this bios chip brand...this is best pic i could get...looks like 25U8 (913??)..I think thats bios chip..on left/underside close to connector edge.
    https://ibb.co/mDyFmZ8
    https://ibb.co/1dNPHBD
