How do I connect a 2010 13" MBP to external monitor?
Discussion in 'Apple and Mac OS X' started by hydralisks, Jun 11, 2010.
  1. doh123
    doh123 Without ME its just AWESO
    VGA is very old.. and analog. You can get much better pictures out of DVI or HDMI
  2. Deathwinger
    Deathwinger Notebook Virtuoso
    VGA is crap analog signal
    DVI is great digital signal
    HDMI is the best, digital video and sound, the perfect setup for video editing. Get a Dell screen with HDMI, plug in some 2.1 speakers into it and every time you plug in the HDMI into your system, you access both automatically, no extra wires needed :)
  3. ifti
    ifti Undiscovered
    Get the HDMI with a HDMI monitor - remember HDMI is the only one out of the 3 that also caries sound!
    Ensure you buy an adaptor that is compatible though, and can carry the audio.
  4. beige
    beige Notebook Deity
    get the HDMI as it more universal on LCD TVs ,maybe one day apple will support sound over HDMI :D , also u can use the cable on other devices like HD DVD players and PS3 and so on , cheers
    Note: if u r planning to use a projector in any thing i think they require VGA port , please double check this info
  5. Seshan
    Seshan Rawrrr!
    Yet, notebook manufactures still put it on there notebooks in 2010. They really need to kill off VGA. But companies (not Apple) are to afraid that customers might get upset.
    @beige They already do support sound.
  6. Xhibit
    Xhibit Notebook Evangelist
    Yeah stick with DVI, its better than VGA and any respectable monitor supports it.
  7. jackluo923
    jackluo923 Notebook Virtuoso
    Vga - greater compatibility, same quality at low or medium resolution. Can't tell the difference between dvi and vga at 1366x768
    DVI/HDMI - less compatibility, digital (it either works or it doesn't), hdmi can carry audio at the same time.
  8. Seshan
    Seshan Rawrrr!
    Actually, DVI/HDMI is more Compatible, DVI/HDMI can go VGA or HDMI/DVI, VGA can go, well no where. VGA is old and outdated and I don't get why OEM's still support it.
  9. jackluo923
  10. akin_t
    akin_t Notebook Evangelist
    Guys while you're correct that DVI is better than VGA for most consumer applications, it is not because DVI is digital and VGA is analog. It is because most of us use LCD displays ... If we used CRT displays the consensus would be different.
    CRT displays are better, it's unfortunate that their construction requires such bulk though.
