How come my computer is not updating past 1509?
Discussion in 'Windows OS and Software' started by kojack, Nov 25, 2018.
  1. kojack
    kojack Notebook Virtuoso
    i installed windows 10 pro on my computer from an iso I had. It’s not updating to the April update. How can I make this happen? Any tricks?
  2. Ultra Male
    Ultra Male Super Tweaker
    You mean 1809 right? there is no 1509.
    What's your current build version. Type winver in an elevated command prompt and tell me your build number.
    kojack likes this.
  3. kojack
    No, it’s 15xx. I will fire it up and find out for you
  4. Ultra Male
    oh sorry you said "past" in the thread title I was thinking it's not upgrading to 1809
    Let's find out your current build number and also tell me, did you perhaps do any tweaks or changes that might prevent Windows update from updating properly?
    You can try the manual upgrade tool
    kojack likes this.
  5. kojack
    I am trying to update to OCT update. It said 10240? Not making any sense to me.
    I will give the manual upgrade tool a try. Report back later. If anyone says that windows 10 has not improved since this version, They are DEAD WRONG. This is horrible compared to the latest version.
    No, I never tweaked anything. Just installed this version, and wanted to update before installing any software etc.
    Ultra Male likes this.
  6. Ultra Male
    if you just installed it, why not do a clean install with 1809? It'd be much smoother than an upgrade
    Papusan and Vasudev like this.
  7. kojack
    Well, I just grabbed this disk, and went to town to make sure it actaully was my hard drive that crapped out. SO, It's there on the system now, might as well dive in and get it going. I know one thing, the SSD is WAY faster than the old drive.
  8. Ultra Male
    Trust me an upgrade from 10240 which is like 7 builds behind the current version is NOT going to go smoothly due to numerous files/registry entries being modified. j00 have been warned. Good luck
    Papusan and kojack like this.
  9. kojack
    All done and working great! What a difference in speed etc. Took awhile, but well worth it. Thanks for the link to the update site.
    Papusan, Vasudev and Ultra Male like this.
