How cold is too cold for a laptop?
Discussion in 'HP' started by mntrryrodriguez, Dec 17, 2007.
  1. mntrryrodriguez
    mntrryrodriguez Notebook Consultant
    SO i turned on my laptop this morning and it was thirty degrees colder than at a normal startup. Its really cold outside. I mean i'm a Floridian and 38 degrees is freeezing for me. My laptop exp. base and laptop sit next to a window. So i'm wondering if having this really cold air from this poorly insulated window will affect it while off, idle or while under heavy workload?
  2. NotebookYoozer
    NotebookYoozer Notebook Evangelist
    the colder the better
  3. TomTom2007
    TomTom2007 Notebook Deity
    Bender: It's so cold, my processor is running at peak efficiency.
    Leela: What are you, a whining machine?
    ____________
    It's not the cold weather you should be worrying about... but Condensation...especially when your laptop is nearby the window...
  4. sly
    sly m1530 owner!!!
    that temp. is ok but try to make sure it doesnt go under 30 degrees
  5. timtravel42
    timtravel42 Notebook Virtuoso
    yeah actually i prefer not to expose my computer components to any thing under freezing 0 C or 32 F
  6. caveman
    caveman Notebook Consultant
    remember that a LCD screen is a LIQUID crystal display. so they may have a lower freezing point than water but it would still freeze
  7. hectorse
    hectorse Newbie
    It's not the Semiconductors I wuld worry about, since their COLD break point is at about 65 K, but stuff like the LCD, battery and specially capacitors I don't know.
    Even then I think -10 C isn't that much of a burden
  8. kanehi
    kanehi Notebook Deity
    I agree, the colder the better is good for the CPU but not for the LCD or battery. Freezing temps are not good for batteries and LCD won't fire up.
  9. mujjuman
    mujjuman Notebook Deity
    quoted for truth
  10. kowell
    kowell Notebook Evangelist
    Quick tip from personal experience....
    A laptop in a car trunk for 4½ hours in an exterior temperature of -35c...NOT good....
    Took 2 hours until I was able to boot it up with positive results... :D
