How can I check what caused a recent system hang?
Discussion in 'Windows OS and Software' started by HerrKaputt, Apr 1, 2017.
Tags:
  1. Rynaus
    Rynaus Notebook Consultant
    This could be anything from a bad driver to corrupt system files to malware. Try the following
    . Run sfc /scannow and see if Windows detects any corrupt system files.
    . Run a good malware checker like MBAM
    . Ensure all drivers are up-to-date, including BIOS and Firmware.
    . I see you have already tried clean install of Windows 10. Does it hang even before you install any drivers or software ? Try to narrow down the problem. First work only with clean Windows and see if it still hangs. What software are you running while it hangs ? Were u just browsing, watching a movie, playing a game or something else ?
    . Also try running some hardware tests like MemTest to check for bad RAM. Did they also replace the CPU ?
    Sent from my ASUS_Z016D using Tapatalk
    Phoenix likes this.
  2. yutzybrian
    yutzybrian Notebook Consultant
    Rynaus likes this.
  3. Vasudev
    Vasudev Notebook Prophet
    @HerrKaputt: Did you try a malware scan using Kaspersky Rescue Disk. You burn it into a flash drive and boot from it to scan whole PC. Also, check SMART status of HDD/SSD. If all else fails, try complete reinstall.
