How can I change my role?
Discussion in 'Site Suggestions, Announcements and Guidelines' started by Wyoming88!, Jul 21, 2019.
  1. Wyoming88!
    Wyoming88! Notebook Evangelist
    I spend a lot of time in the Panasonic forum and motorized vehicles. So I would like my role changed if you can from Notebook Consultant to something else.
  2. t456
    You can set it yourself to anything you like. Check your account under 'Personal Details' -> 'Custom Title':
  3. Wyoming88!
    i did not see that in mine
    Isi it a moderator thing? I am clearly not one
  4. ALLurGroceries
    ALLurGroceries   Super Moderator
    You need to be automatically promoted to a new user group in order to change your user title. I'm not sure what the exact threshold is, and whether it's by posts or how long you've been around.
    katalin_2003 likes this.
  5. downloads
    downloads Super Moderator Super Moderator
    It depends on the number of posts made with thresholds as follows (the number shown is the minimum number of posts needed to get the title)
    Newbie - 0
    Notebook Enthusiast - 10
    Notebook Guru - 50
    Notebook Geek - 75
    Notebook Consultant - 100
    Notebook Evangelist - 300
    Notebook Deity - 700
    Notebook Virtuoso - 2000
    Notebook Prophet - 4000
    Notebook Nobel Laureate - 7000
    I's also possible that senior users (with at least 700 posts) can edit the title at will - I can't test that as a moderator, someone with at least 700 posts who isn't a mod could check that out though.
    katalin_2003 and Wyoming88! like this.
  6. Wyoming88!
    I guess I have a lonnnng way to go
  7. saturnotaku
    I have the ability to change my title.
  8. t456
    Yes, there's a minimum post count. Not sure what the threshold was, but could edit it before becoming a moderator and iirc it was under 1,000, so that 700 sounds very plausible. Can also change custom titles of a user with > 745 posts, but not for someone with < 570 posts.
    Guess that leaves spamming the forum with empty posts then, eh o_O ? Think one should drink something about ten times a day, so this should be doable within a month or so, if you're really that desperate. It's a also traffic ... of sorts, I guess :vboops: .
  9. Wyoming88!
    I have like a lot to go. If I did just spam Radom threads until I hit 7000 then I gues I could buy I don’t want to be banned for that. In fact it’ll take me around 7-12 months to get there. Maybe 12-24. I don’t know but I’m off to DC.
    t456 likes this.
