  1. mendameister
    mendameister Notebook Geek
    I have an Alienware m17x R4, i recently finally decided to go for the triple monitor set-up i've always wanted, but then AFTER buying the monitor and 3 hdmi's realized that i had no idea what I'm doing -.-
    So, describing my problem, i have 3 ASUS VS228's and I know until i get a usb 3.0 to hdmi adapter i can only use 2 of the monitors (+ my inbuilt one). However, I'm unable to do so, I have a AMD 7970M graphics card. and connected one of my monitors with an HDMI and the other with a VGA cable. But when i go to Catalyst control center, it says "To extend the desktop, a desktop or display must be disabled". How do i fix this?
    Also, Can anyone guide me as to how i can set up my triple-monitors? I just realized today that the laptop doesn't have a DVI port so i can only connect 2 monitors for now. I plan to play games like Guild Wars and League of Legends across all 3 screens. Can provide a picture of my set-up though it's unnecessary i just have 3 of the same monitors lined up in an arch on my corner-desk. All help is appreciated. Tyvm
  2. octiceps
    octiceps Nimrod
    You need to set up Eyefinity, that's all I know. I never got around to doing it on my ASUS G73JH before I sold it.
  3. mendameister
    I tried Eyefinity but it gave me the error that i can only use 2 screens at once. It lets me use both monitors without the laptop screen, but for now i want to use my laptop with 2 monitors until i get a wire/wireless keyboard & usb 3.0 to hdmi adapters.
  4. octiceps
    octiceps Nimrod
    Sorry I can't be of more help. I no longer have a laptop with an AMD GPU. :(
  5. radji
    radji Farewell, Solenya...
    You maybe can use all three together. But I wouldn't advise a USB 3.0 to HDMI adapter. Get a MiniDP (Mini DisplayPort) to HDMI adapter for one, a VGA to VGA for another (which you state you've already got) and then the primary of the three, because you still have to specify one as your primary, should run off the HDMI.
    This will be what the miniDP to HDMI cable will look like. The miniDP port is to the right of the HDMI port.
    Once you get them connected, go to your Windows screen resolution control panel. It's under the Display Control panel (adjust screen resolution).
    You'll need to set your monitors to the correct positions of where they sit on your desk, e.g., if your number 2 monitor (clicking IDENTIFY will tell you which monitor is which) is the right-hand most monitor on your desk, you need to drag it to the right position in the control panel. Same thing with the left-hand most monitor and center monitor. Finally, you need to click on each display and set each one to extend these displays from the multiple monitors option.
    Now once you hit apply and ok, you should be able to setup Eyefinity in CCC.
    daveh98 likes this.
  6. mendameister
    I tried what you said, before getting an adapter for the 3rd Monitor i need to figure out how to get these 2 to work first, i can only keep 2 monitors active at a time. the VGA to VGA one is connected, and main hdmi port on laptop is connected to another monitor. But i can't manage to keep 3 screens active at once. It says "The display settings could not be saved. Please try a different combination of display settings." when i try to keep 3 monitors on "Extend desktop" mode. Even if i try to duplicate displays on all 3 monitors, i feel like there's something restricting me from running 3 monitors at once.
    7970M, M17x R4, Win8, SSD's, all Drivers updated.
  7. radji
    Are you setting it in CCC or in the Windows screen resolution control panel?
  8. mendameister
    Windows CP. CCC won't even show me the third monitor.
  9. Fat Dragon
    Fat Dragon Just this guy, you know?
    Is the notebook's monitor perhaps running as the third monitor? I suspect if you're trying to run three external monitors you can't use the notebook's built-in monitor along with them.
  10. mendameister
    It's only allowing me to run 2 monitors at once, Notebook + 1 monitor or 2 monitors w/o notebook. I'm trying to run 3 monitors with the notebook being the primary one.
