Help With WWAN Connection Utility
Discussion in 'Lenovo' started by Stangs55, Oct 16, 2008.
  1. Stangs55
    Stangs55 Notebook Enthusiast
    Just finished clean Vista install since my factory T400 was much slower than it should have been. I'm certainly glad to have gotten rid of Access Connections as it took 3-4 minutes to load before. Now I'm just using Vista to manage my wifi and it's much better.
    However, I'm now missing something vital. Before, I was able to use Access Connections to connect using my Ericsson f3507g AT&T WWAN to the AT&T network via my iPhone 3g sim card and the username/password supplied around these forums somewhere. But now that Access Connections is gone, I have no way of accessing my WWAN to tell it to connect. :(
    I had thought I'd read on here previously about a Ericsson (or someone's) WWAN connection utility that I could just manually enter the parameters for and it would connect...but I can't seem to find it (or the thread).
    Ideas? There's gotta be a better way than Access Connections to do this...Thanks in advance.
  2. bananaman
    bananaman Notebook Consultant
  3. jcovelli
    jcovelli Notebook Deity
    just make the connection with the vista dial-up manager. (make a new network connection -> dial-up)
    the number should be #777
  4. Stangs55
    I had tried this in Vista prior to using Access Connections, but was unable to make it work. You have a link to some working directions for this under Vista?
    thanks for the advice.
  5. Stangs55
    Still unable to get my iPhone sim to work in my T400.
    I keep seeing that I need to set my Access Point name to 'wap.cingular'...but I have no idea where to do that.
    FYI, I'm trying to connect with a new dial-up connection using:
    Username: WAP@CINGULARGPRS.COM
    Pass: CINGULAR1
    Number *99# OR *99***#
    Ideas on getting this to work under Vista Ultimate?
    (Oh...and the ATT Communication software doesn't work)
  6. petter
    petter Newbie
    You could try this (works on XP):
    Set up an extra initialization command for your modem
    AT+CGDCONT=3,"IP","YourAPN" where YourAPN should be something like "internet.cingulargprs.com".
    To do this - go to control panel/phone and modem options/your modem/advanced/extra initialization command.
    AND change the phone number in your Dial Up Connection to *99***3#
  7. bananaman
    Try leaving username and password blank. At least that's what AT&T's instructions say.
    Tell us how that works.
  8. petter
    petter Newbie
  9. Renee
    Renee Notebook Virtuoso
    I did a clean installation on my t61p. Then I added the desired lenovo display utilities. I called them as the were designed to be called.
