Help with On Screen Pop Ups!!
Discussion in 'HP' started by RedLineShift, Jul 2, 2012.
  1. RedLineShift
    RedLineShift Notebook Enthusiast
    Hey guys,
    Just have a quick question about my Envy 15 3040nr now that I switched out the Intel SSD and swapped in a larger 256 Crucial M4. I did a clean install, and I am currently missing 1 driver under the "other Devices" category: PCI Device.
    Next, I cannot find this driver, the onscreen utility one that pops up when you change volume or brightness (sp55152.exe I believe) since it no longer shows up on HP's website.
    Also, does anyone know of a good search function like Linux or Mac? For example, I want to be able to hit a general shortcut/macro and type in diablo and auto run diablo 3 :D
    Sincerely,
    Brian
    p.s. I have done my searching throughout the forum and also on google for more than a day now, so any help would be really appreciated so I can solve this immediately.
  2. namaiki
    namaiki "basically rocks" Super Moderator
    The Windows Start menu can kind-of do that. Not always the program you are looking for though.
  3. tordogs
    tordogs Notebook Consultant
    Is this the driver you need?
    ftp://ftp.hp.com/pub/softpaq/sp55001-55500/sp55152.exe
    Don't know if the link works, maybe you tried it already.
    Yep, think it's broken. Copied this part of the HP FTP listings and the 55152.exe just doesn't show up for now--maybe an update on the way?
    07/01/2012 03:07AM 9,912 sp55151.cva
    07/01/2012 03:07AM 6,333 sp55151.html
    07/01/2012 10:13AM 11,141 sp55152.cva
    07/01/2012 10:13AM 6,615 sp55152.html
    07/02/2012 01:29AM 178,240,168 sp55153.exe
    07/02/2012 01:29AM 5,891 sp55153.html
    07/01/2012 03:01AM 181,735,760 sp55154.exe
    07/01/2012 03:01AM 5,852 sp55154.html
    06/30/2012 04
  4. RedLineShift
    yea tried it already and even just searched for the driver on google. sadly, I just cant find it. I am tempted to install 3rvx like I have on my envy 14, but then it will lack the brightness control.
    also, yea I kinda do use the windows search, but I remember there was a search program that was similar to linux/mac OS that I used to have. Just cant remember it :/
  5. MacHater
    MacHater Notebook Evangelist
  6. RedLineShift
