Help With My Hp Laptop!! To Hot!
Discussion in 'HP' started by MaliOwnz, Dec 14, 2008.
Does your laptop doing this??
  1. YES! ITS GET VERY HOT, WHEN I PLAY GAMES!
    4 vote(s)
    28.6%
  2. YES! ITS GET VERY HOT AT ALL.
    6 vote(s)
    42.9%
  3. No it doesnt get so hot?
    6 vote(s)
    42.9%
  1. MaliOwnz
    MaliOwnz Notebook Enthusiast
    Heey guys...
    I need help with my HP laptop. I always play alot of games and my laptop gets very hot, I have HP Pavilion dv9000, My friends laptop ( he has an Acer (LOL)) and its never get so hot as mine do, so i was wondering what this could be.
    In the picture the red circle shows where it gets hottest...
    Ill like to know what that is a processor (idk how to speel it), my graficcard or something else??
    Thanks :D :notworthy:
  2. Tinselworm
    Tinselworm Notebook Deity
    dont worry, he has an Acer, yours OWNS ( that is the in vent for the CPU cooler, if you cover this then it gets hottter!!!! )
  3. Melody
    Melody How's It Made Addict
    Well obviously gaming will increase the temperature of your laptop. How "hot" is hot though? Is it uncomfortably hot or is it warm or what? I had an old HP dv2000 which overheated really really really bad, but I doubt yours is that bad. Mine actually shut down since it got so hot.
    Check your vents to see if anything is blocking them and avoid using it on your laptop or on your bed where something could potentially block them(such as sheets or clothes).
    Also you can download HWmonitor to see your temperatures while you game and check which part in your laptop is heating the most. Chances are it's probably either the GPU or the HDD heating up though.
  4. Bog
    Bog Losing it...
    It is normal for that area to get hot because that is where hot air from the heatpipe is expelled. The fan sucks air in through the square vent and pushes it out through the side vents in the back and on the side.
  5. MaliOwnz
    Is it the processor there is sitting there????
    could i mayby change it to one that doesnt get so hot?? =) thnx for the help guys .. :D
  6. Blue_Wolf
    Blue_Wolf Notebook Consultant
    Download "GPU-Z" and tell us what temps you get for gaming and idle.
    Have you considered using a cooler?
    You don't use it on your lap while gaming do you...?
  7. MaliOwnz
    I game on my laptop =) where to you get such a cooler... yesterday i order an USB cooler . You sit it up under your Laptop and then its cooling. It have 3 ventilators...
    What u guys think i should do with this problem?? :D
  8. Melody
    Well first of all, you should download GPU-Z of HWMonitor to read your temperatures. Both these programs will check the temperature of each of your parts so just record the temperatures while gaming to see if there are any problematic temperatures.
    Also, clean out the vents and avoid gaming when the laptop is anywhere but on a solid surface such as a desk. This will reduce the chance of cloth or dust getting into the fans.
    The cooler is a good idea and also think about elevating the back of your laptop just a bit with either a book or something. That 2-3cm will improve the air flow under the laptop and decrease the heat.
  9. Moderate
    Moderate Newbie
    Hi, I googled this thread, and decided to register and post because I seem to have the same problem with my Pavilion dv5. It gets EXTREMELY hot.
    Not 'wow, that's pretty warm, what's wrong with your computer?'
    more like 'ouch, my lap' or 'wow, why is my desk burned?'
    any idea why?
    I have a warranty on it, and I could take it to best buy and have them ship it back to hp for a new one, or they'd repair the fan or whatever.
    But I don't know if I feel like waiting for six weeks while they do that.
  10. roosta
    roosta Notebook Evangelist
    use HWMonitor to give us some numbers. saying "hot" is useless.
