help with laptop replacement
Discussion in 'What Notebook Should I Buy?' started by flavarican, Feb 2, 2017.
  1. flavarican
    flavarican Newbie
    Hello everyone,
    I will keep it short and to the point. I have an Asus n550jk. To fix it I need to solder a burn piece on it. In the meantime I need another laptop. I am looking to replace it. It has a 4700HQ and a 850m card. It cost me $700 3 years ago. What are my options nowadays?
    It seems that all the new i5 chips and all the new i7 chips that end with U are not as good as the 4700HQ. I am also a little confused on the 1050 for mobile, is it just as powerful as the 1050 for desktop? I ask because the 1050 and 1050ti in the newer laptops do not have the "m" as in 1050m .
    1) What is your budget?
    ~$700
    d. Mainstream; 15" - 16" screen
    3) Where will you buying this notebook?
    US
    no preference
    yes
    programming
    Both, teach part time.
    light gaming (diablo 3, terraria, ark etc)
    doesn't matter
    buying online is fine
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    1920 *1080 no need for 4k
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    all my laptops have been ips , never had matte
    Build Quality and Design
    no
    asap, 3-4 days
    until I drop it or kill it with static to get another one
    Notebook Components
    if it saves money then get the version with the the crappy 5400 rpm, i have 2 ssds ready to swap
    Nope.
  2. don_svetlio
    Well, currently, you're looking at one of these.
    Lenovo Legion Y520
    Asus GL553 Strix
    HP Pavilion 15 Gaming
    If you can live with a TN panel rather than IPS
    Dell 7567
    Acer VX15
  3. flavarican
    flavarican Newbie
    hello don_svetlio,
    the Legion Y520 is $1200 ( couldn't find a link)
    the Asus GL553 is $1000 http://store.asus.com/us/item/201612AM300001434-ASUS+GL553VD-DS71+15.6
    the HP Pavilion 15 $800 after changing the cpu (the link HP Pavilion Power Laptop - 15t Quad w/ 2GB gfx )
    Are you saying that there is nothing less than 800 as of this moment? did i get lucky with my Asus 3 years ago?
  4. don_svetlio
    Y520 should start at 900$ but I guess it's not officially out yet
    Well - if you want a 1050 and IPS screen, yes. 800-900$ is where you have to start. The N550 was originally priced at 1000$ or so but price dropped when the next gen came out. If you look at last gen devices like the Dell 7559 or Lenovo Y700 - you will find lots of 600-800$ 960M machines. Thing is, 960M is a rebranded 860M which is only about 20% faster than your current 850M - not a worthwhile upgrade. A 1050 is about 50-60% faster than your 850M and a 1050 Ti is about twice the performance of your current GPU. You could also check for 970M machines as the 970M is on par with a 1050 Ti but those tend to be around 1000$ as well.
  5. flavarican
    flavarican Newbie
    I see, because the next gen of the 860m is not that good, I might as well spend the extra and get a 1050-1050ti-1060 laptop. Thanks for your help. Looks like the msi is winning. I don't really like that orange on the asus one but now I keep reading how 1050 with 2 gigs is a waste. No one is satisfied!
  6. don_svetlio
    2GB of VRAM is indeed very limiting. Even my 3GB 970M is reaching the VRAM cap.
    As for the Asus - it's actually RGB (the keyboard) - the lid has orange accents though.
    As for MSI - avoid the low end ones. If going MSI, GS or GT series only.
