Help with Alienware 15 R1 bios error
Discussion in '2015+ Alienware 13 / 15 / 17' started by Johndill, Mar 31, 2020.
  1. Johndill
    Johndill Notebook Consultant
    I was prepping my laptop to sell it and during a bios flash it froze interrupting the flash and bricking the bios.
    I was able to restore a good bios with my hardware flasher to A01 and after that I am getting this error in the bios...
    In windows I have updated to A02 A04 etc up to A10 but the error remains.
    I have reset the cmos but the error is still there.
    Does anyone else have an idea on how to fix this? It seems to take the laptop longer to post than before and can't sell it in this condition. Thanks in advance. :)
    c69k likes this.
  2. Spartan
    Spartan Super Tweaker
    Did you reset the BIOS back to factory defaults after you flashed it again?
    c69k and Johndill like this.
  3. Johndill
    Yes I believe I did but the error still shows up. After I close the error and try to enter the "performance options with alienware graphics amplifyer" it will freeze. At one point the error didn't show up any more and the "performance options with alienware graphics amplifyer" settings were greyed out. I don't have a graphics amp, it is an observation with that menu. :)
    c69k likes this.
  4. Muezick
    Muezick Notebook Consultant
    try full cmos reset?
    Unplug cmos battery + full battery + DC power, and RAM (For safe measure) and hold power button for 10 seconds
    Put all back together. try again
  5. Johndill
    I've tried that but no difference. I have discovered that the intel ME (management engine) firmware is corrupted also, although I have restored a good bios I now have to try to find and flash a good ME firmware. :-( It is probably the cause of the error in bios.
    c69k likes this.
  6. Johndill
    Thank you for your help. :) I believe the intel ME firmware corruption is the cause.
    c69k likes this.
  7. c69k
    c69k Notebook Deity
    @Johndill
    This could be a long departure from your problem, but maybe this can trigger an idea how to fix your problem:
    1. I had very similar problem with 13 r3 after flashing a new bios 2 years ago. I had no pop-up as in your picture, but after the flash, I was not able to install IME and IRST driver in Windows 10 (saying incompatible system and seeing yellow marks in Device manager).
    However, the Bios let me enter Windows 10.
    Switching from RAID ON to AHCI in Bios solved this problem (using safe mode procedure) and I could install both with no problem.
    I had exactly this symptom during the above troubleshooting, plus laptop would not completely turn off, the lights (KB) would stay on.
    Luckily you have the flasher !!!
    Johndill and Spartan like this.
  8. Johndill
    Yes, it is very similar to my issue actually as I cannot install the driver either as it will say something like "platform not supported" , however unfortunatly I do not have the intel managment engine in device manager at all as it is completely missing. I believe because the firmware is missing or corrupt, device manager is unable to find the device at all.
    Ah thanks, so the slow post does have something to do with the ME not working correctly. :)
    Yes, the CH341A flasher with the SOC clip is very usefull to have around. :)
    I believe all Alienware laptops after this gen have a bios USB recovery, just not the haswell systems.
    c69k likes this.
  9. c69k
    c69k Notebook Deity
    @Johndill
    I forgot, yes post was also about 1 minute during the problem I had.
    'platform not supported', correct.
    Johndill likes this.
  10. c69k
    c69k Notebook Deity
    @Johndill
    During past 3 years I have seen this problem with Dell lapotops. The solutions I have seen were HW flashing new IME or MB swap.
    I have also HW flashed 120W 1060 vBios (compared to original 78W). What a difference !!!
    Vasudev and Johndill like this.
