Help To chose an alternative for Macbook Pro
Discussion in 'What Notebook Should I Buy?' started by Neeraja Sanjay, Feb 18, 2017.
  1. Neeraja Sanjay
    Neeraja Sanjay Newbie
    1) What is your budget?
    1lakh
    Mainstream; 15" - 16" screen
    Or
    Desktop Replacement; 17"+ screen
    India
    Dislike: acer
    No
    Graphic designing, vdo editing, Web development
    Both
    Yes, Most probably FIFA Latest
    5+
    Yes
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows 10 or Mac
    Screen Specifics
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy
    Build Quality and Design
    No
    In next 2 months
    5-6 Years
    Notebook Components
    I need an SSD of Minimum 256gb
    No
