Help to choice a laptop
Discussion in 'What Notebook Should I Buy?' started by lhozedu, Sep 10, 2016.
  1. lhozedu
    lhozedu Newbie
    General Questions
    1) What is your budget?
    ~700$ or 800$
    Mainstream; 15" - 16" screen
    USA
    a. Like: Dell, Asus, Lenovo
    b. Dislike: HP
    Yes
    coding, games development, programming, maybe some games
    both
    8) How many hours of battery life do you need?
    ~4h
    I'll buy online
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    1080p it's fine
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    matte
    Build Quality and Design
    yes
    one month
    at least 2 or 3 years
    Notebook Components
    SSD for system
    No
    I'll use this laptop most of the time for coding, therefore I need a good keyboard and a good screen.
  2. lhozedu
    lhozedu Newbie
  3. John Ratsey
    Look in Dell Outlet for the Latitude E5570 and check Dell Outlet's twitter feed for coupons. That notebook will give you everything you want except the style. For something more stylish there's the XPS15 9550 / Precision 5510 but I doubt you will find any within your budget.
    John
  4. lhozedu
    lhozedu Newbie
    So heavy and fat, nothing more light and thin?
  5. Krowe
    Krowe Notebook Evangelist
    Well, if you want thin and light with any sort of decent build quality, you gotta be willing to pay for it.
    Kent T likes this.
  6. lhozedu
    lhozedu Newbie
    and another brand?
  7. Krowe
    At that price point, you're not going to get a lot of build quality (or horsepower) in a typical consumer laptop. Business class refurbished is about as good as it gets, but they aren't pretty.
    For thin and light, sure they exist at that price point, but they had to make a lot of compromises to hit that price point. Performance, construction quality, component choices and durability all take a hit to make it cheap. You get what you pay for.
  8. John Ratsey
    Perhaps review your requirements. Probably the first priority is a good quality high viewing angle (ie IPS or equivalent technology) FHD display. Glossy may be OK (but it's more vulnerable to reflections from lights) as matte tends to be only used on business notebooks. Do you want a keyboard with a numpad or without? Your preference may depend on what you are used to.
    If your reading vision is good then you could also consider a 14" notebook which would widen your options (eg Dell Latitude E5470 / E7470) and give you more portability. A good quality wide viewing angle FHD screen is very legible but everything will be slightly smaller than on a 15.6" screen.
    John
  9. lhozedu
    lhozedu Newbie
    A matte display it's very important to me, also a keyboard with a numpad, for that reason I need a 15.6" screen.
    I can sacrifice construction quality for more thin and light, but with the good quality display, good quality keyboard (with numpad) and good performance (i think that 6th gen i5 hq its ok or the i7 6820HQ that comes with E5570 its really necesary?)
    thank you so much for the help
  10. Krowe
    What you're describing is basically a business notebook that is within your budget! (From the outlet of course). Why the focus on thin and light?
