HELP SWAP: Alienware 18 R1 4800MQ GTX880 SLI 16GB to Alieware 17 R3 6820HQ GTX 980M 4GB, Worth it?
Discussion in '2015+ Alienware 13 / 15 / 17' started by CSARQUITETO, Nov 26, 2019.
  1. CSARQUITETO
    CSARQUITETO Newbie
    One guy want to swap the alienware with me:
    My config:
    -FHD Screen
    -GTX 880M SLI 16MB
    -16GB of ram
    -SSD Samgung 850 pro 512GB
    -HDD 700GB
    He config:
    Alienware 17 R3 6820HQ
    -4k Screen
    -GTX 980m 4GB
    -16 of ram
    -SSD m2 128GB
    -HDD 1TB
    I use my alienware 18 for autocad and graphics softwares and play some games. Worth get this alienware 17 ? because my alienware is little old, SO BIG and heavy and i dont know if my laptop have i good value.
  2. Terreos
    Terreos Royal Guard
    The 980m was a pretty big jump in performance over the 880m. But in sli the 880m still seems to outperform the 980m. But that’s gaming related.
    But you’re getting a 4K display on the 17” and a two generation newer cpu. Productivity wise that would be good for your Autocad work if you don’t use external monitors.
    It’s a bit of a toss up in my eyes. The 18” Alienware’s are kinda unique since that size isn’t made anymore. I think I’d lean trading it for the newer cpu and better screen though.
    Papusan likes this.
  3. ssj92
    ssj92 Neutron Star
    You can upgrade the 18 to 980M SLI lol
    From a performance standpoint it isn't much of an upgrade.
    BUT you get the amplifier port so you can add an amplifier and add like a Quadro GPU in the future as well.
    4K screen is also nice.
    It's a tough call but the trade isn't one sided so it's fine either way you go
    The 18 was known to have motherboard failures so idk
    Terreos likes this.
