Help request: Mobile dGPU passthrough
Discussion in 'Sager and Clevo' started by lost_0x10, Mar 7, 2018.
  1. lost_0x10
    lost_0x10 Newbie
    Machine: Clevo P650HP6
    Issue: Need a 1060 6G vBIOS
    Additional info: using vfio-pci, kernel 4.15.7-1, SPICE for display.
    I have a VM setup on QEMU and stuff runs ok at the moment except the NVIDIA GPU throwing "error 43". Possible fix is passing the dGPU vBIOS to the VM on launching it but extracting it on my system has proven difficult.
    I'd like someone to send me their vBIOS dump, better yet upload it to techpowerup or preferred vBIOS repository.
  2. Danishblunt
    Danishblunt Guest
    Why don't you take GPU-Z and dump it yourself?
  3. senso
    senso Notebook Evangelist
    In systems with vBIOS in the BIOS GPU-Z doesn't/cant dump it.
    The normal route is dump BIOS, then extract VBIOS module from the BIOS.
  4. Danishblunt
    Danishblunt Guest
    Sorry, wat. I've never had any issues with dumping vBios with GPU-Z. My 1060 dumped no problem. Sometimes GPU-Z can be a jerk and tell something like "hardware not supported" or any other kind of error, which a restart usually fixes.
  5. senso
    You never had the sadness of seeing this?
  6. Danishblunt
    Danishblunt Guest
    As already stated, I've seen it couple of times, nothing a restart didn't fix. When I tried to dump my 1060 BIOS the first time I had this exact error, then I simply restartet and tried again, and suddenly got myself a successful dump.
  7. Meaker@Sager
    You have a P370EM IIRC which uses an MXM module with a dedicated vbios.
  8. lost_0x10
    lost_0x10 Newbie
  9. senso
    Just use fptw, easy to do, dump the whole BIOS(or as much as your system allows).
    Then post the bin file here.
  10. lost_0x10
    lost_0x10 Newbie
    I did dump the the system BIOS but was unable to find out which was the vBIOS from all that nonsense, tried with Mobile Pascal TDP Tweaker(MPTT), maybe you guys can show me a better way.
    Resorted to this command:
    sudo sh -c 'echo 1 > /sys/bus/pci/devices/0000:01:00.0/rom; cat /sys/bus/pci/devices/0000:01:00.0/rom > 1060.rom'​
    Do note the GPU had to be loaded with vfio-pci for the QEMU VM, trying to execute the same command with the GPU off (by bbswitch or whatever), or on (optirun, primusrun,...) yielded an I/O error.
    Some stuff I tried to solve "error 43":
    1. Confirmed the dumped vBIOS with MPTT.
    2. Created a version of the vBIOS dump with modified limits.
    3. Passed the unmodified vBIOS to GOPupd(change it to UEFI),
    4. Created a modified version of the UEFI vBIOS.
    5. Verified the UEFI state of the UEFI vBIOSes with rom-parser.
    6. nvflash reports a size mismatch for the UEFI vBIOS.
    Launched the VM with the four vBIOSes I had, error 43 was still there.
    Edit: my dGU is mapped onto the address "01:00.0"
  11. senso
    Virtualbox in Windows doesn't allow PCIe pass through, so theres that.
    Grab AFUWIN, click save, save it, and upload the file here.
  12. lost_0x10
    lost_0x10 Newbie
    Am running Arch linux with Windows 10 in QEMU, will update on solving "error 43".
    Passing a GOP'd BIOS to the VM: doesn't show up(as UEFI) in the VM's GPU-Z instance.
    Passing coreboot having the GOP'd BIOS as optional during its compile: doesn't show up(as UEFI) in the VM's GPU-Z instance.
    EDIT: Clarified the not showing up
  13. Meaker@Sager
    What CPU did you go with by the way?
  14. lost_0x10
    lost_0x10 Newbie
    Not sure about the question, so here you go:
    Actual hardware: 7700HQ
    KVM cpu: host(7700HQ), 1 socket, 4 cores, 1 thread​
