help regarding w500
Discussion in 'Lenovo' started by martinmach, Oct 15, 2008.
  1. voostro
    voostro Notebook Evangelist
    thanks guys ! good info
    ive been window shopping with $1500 in my right pocket for a month now and had a look at this w500, read alot about the quadro and fire gl cards too.....
    was hoping to get some "real time/exp." from others on gaming with em'
    the discount on this puppy is incredible right now with stackables and the specs you get
    only thing holding me back is what i been hearing about the screen :(
    can you say it's more than ok or livable ??
    both the ccfl one and the upgrade.....
    thanks much
  2. Jayonhavok
    Jayonhavok Notebook Consultant
    Hi Martin,
    No you don't. It will work fine without changing the drivers.
  3. Myleftnut
    Myleftnut Notebook Enthusiast
    I heard the WUXGA screen on the W500 isn't very good. Problems such as dim backlight and colors seeming a little washed out. The WSXGA+ is great though and I like it. I've had mine for a month now. As for shipping, it took about 7-10 days for me to receive min as well. I haven't tested battery life myself, infact, I haven't even opened the package for the battery yet. I wonder though, how does one get 6+ hours with that 9 cell battery in linux? I thought I read that the W500s weren't very battery optimized in linux?
    About the games, I've been able to play Call of Duty 4 on 1680x1050 but framerates weren't exactly the smoothest at all times, lowering it to like 1440x900 or lower became smooth.
  4. The Fire Snake
    The Fire Snake Notebook Virtuoso
    All the screens seem luck of the draw and peoples expectations vary greatly. In my case I am very happy with my screen, no complaints, but I have seen horrible screens in person as well(not just pictures). It is luck of the draw but I think most people are happy with their screens. Pro photographers, well they are very picky...:D
  5. voostro
    any sugar momma's out there wanna help me get a W700 ?!
    plz
  6. ideoteque85
    ideoteque85 Notebook Consultant
    One quick question. This might be dumb but Lenovo has been pretty explicit about which as to which screen comes with LED or CCFL(WXGA+ WSXGA+ etc). However, it seems like they do not mention how WUXGA is lit. I'm 99.99% sure that it is CCFL.
  7. martinmach
    martinmach Notebook Evangelist
    Thanks for the Replies and valuable suggestions :)
    i read that WUXGA on the w500 is kind of dull and has very low brightness. i am thinking of saving up that upgrade money and buying an external display.
    i am thinking of leaving the stock hard drive(upgrade it to intel ssd next year ;) ) and getting turbo memory 2.0 to use the user pinning option, i heard it saves battery and access of applications is very fast. any idea on this?
    i will get that vista 64 as you suggested. any difference over the 32 bit one?
    i am assuming your shipping info is regarding w500, than it is great news.
  8. martinmach
    it is CCFL, there is no LED screen for W500 as per the specs
  9. The Fire Snake
    I am not sure about the WUXGA. You would need to check the nit rating to see how bright it is. I haven't looked at the specs of the new models, but the T61p used WUXGA screens that were 175 nit. The other T61 screens were 200 and 220 nits. So from the specs the WUXGA was supposed to be a little bit dimmer, but from what people told me they said they couldn't tell the difference between it and a 200 nit screen. I have never seen a WUXGA screen on a 15" LCD in person. They are impossible to find in the flood of budget 1280x800 machines that are all over the place. Therefore I took the safer option and went for the WSXGA+ screen. I would however love to try a WUXGA screen. Just an idea for you since you are going for one of the few models that allow you to choose a WUXGA screen, which is awesome for screen real estate, you might want to take a chance.
    I don't know too much about turbo memory 2.0. The 1.0 version was not worth it and I choose to not get it. In fact it caused a lot of BSODs and was more of a problem than it was worth. BTW - turbo memory only works with Vista, so if you are planning on running an instance of XP or Linux it won't be utilized.
    As I mentioned above, Vista 64 is nice but can be a problem running old 16 bit programs and interfacing with old hardware that doesn't have drivers that work with a 64 bit OS. Overall though it is really nice and pretty much works with everything but the decision is yours. I choose Vista 64 since I wanted to utilize my 4GB of RAM(32 bit Vista can only access something like 3.2GB of Ram, while 64 bit can access a lot more!) and most, if not all my hardware I was going to use with the machine would be new. The place you might run into 16 bit programs are with installation wizards of older programs. I ran into a couple of these issues with 2 old games I had that had 16 bit installation wizards. I was able to get around the wizard, in this case, and the actual game ran fine. Most my games I play on it are atleast 4 years old and they work fine.
    The question for you is are you going to be using old hardware or old programs frequently?
    My shipping info was regarding my purchase of a T61, T61p and Lenovo bluetooth mouse(just got it yesterday- in about 3 days!!!), not the W500.
  10. martinmach
    Thanks to all of you for your advise. you really helped me to make a good buying choice. i will be ordering it sometime tomorrow. i am thinking of getting a backpack too. do you think w500 will fit this:
    http://www.amazon.com/Swiss-Gear-SA...5?ie=UTF8&s=electronics&qid=1224296026&sr=8-5
