Help, problem with Clevo P170em
Discussion in 'Sager and Clevo' started by Ignaciotro, Sep 8, 2017.
Tags:
  1. Ignaciotro
    Ignaciotro Notebook Enthusiast
    that in any case all opinions and supports are well received
    I thank you
  2. Ignaciotro
    Already, it is what I am beginning to think that is what has happened because it has not been normal. he worked and I did not. we'll see where it ends
  3. Danishblunt
    Danishblunt Notebook Deity
    As I said, the oven will very likely fix it, but it's only temporary.
    I don't know what you're doing with your notebook, if you intend to play new games, then get the AMD GPU, if u're doing something else or just playing something really lightweight games, then go for good thermal compound and make sure the notebook is cool at all times, then the oven fix will let it last longer, maybe even years.
  4. sicily428
    sicily428 Donuts!! :)
    I think that a cpu like i7-2670qm could manage a gtx1060
    https://www.notebookcheck.net/Review-Clevo-P170EM-Notebook.73442.0.html
    here a comparison with a i7-6700hq
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700HQ-vs-Intel-Core-i7-2670QM/m34954vs1982
    edit
    no no no sorry my bad a i7-2670qm is not enough :confused:
    these could be better:
    i7-2760qm
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700HQ-vs-Intel-Core-i7-2760QM/m34954vsm949
    i7-2860qm
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700HQ-vs-Intel-Core-i7-2860QM/m34954vsm103
    i7-2920XM
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700HQ-vs-Intel-Core-i7-2920XM/m34954vsm459
    i7-2960XM
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700HQ-vs-Intel-Core-i7-2960XM/m34954vsm2390
  5. Meaker@Sager
    The x7xx and above did tend to have a fair jump in frequency back then.
  6. Ignaciotro
    a question. today I have tried to remove all ram and boot the clevo, and do the same. When removing the memory should not it beep at boot? will not the motherboard be the wrong one?
  7. Prostar Computer
    No memory will result in no POST, but the system will not beep or throw any alarm. Usually it will power on, then off after a short period of time.
  8. Ignaciotro
    okay. I asked because today talking to a friend who has a computer store told me that all the computers that give alarm with beeps if there was no memory ram. and that this when not doing it was the bad motherboard
  9. Prostar Computer
    That could depend on the BIOS developer. Many systems (desktops included) I've tested will often go into a boot loop, no alarm. Clevo systems tend to simply not POST.
  10. Ignaciotro
    Ok. it is the insecurity of the one who does not know. Thank you very much for the answers
