Help, problem with Clevo P170em
Discussion in 'Sager and Clevo' started by Ignaciotro, Sep 8, 2017.
Tags:
  1. Ignaciotro
    Ignaciotro Notebook Enthusiast
    Hello .
    My laptop (clevo p170em) have a problem. When powered on only show the power button light in white and the bluetooth in orange. Then show three blinking lights (num lock, caps lock, scroll lock) and the fan runs, and past few seconds then the laptop powered itself off. The screen always black
    you tell me what happens, or what does that code indicate?
    Best regards
    Ignacio
  2. Danishblunt
    Danishblunt Notebook Virtuoso
    it basicially means Graphicscard is dead.
  3. Ignaciotro
    F...! Sure? Because a new graphics card is minimum 160€
  4. Danishblunt
    You can try and bake it in an oven. The blink and fan spinning is basicially happening because your notebook can't detect the temp sensors of your card.
    Also upgrading your card might not be a bad idea tho, you can get much more performance in games with an upgrade.
    here is a video on how linus was doing it.
  5. Ignaciotro
    thank you very much friend. can you tell me what temperature and how long is the card in the oven? sorry but my english is not good enough to get to understand it in the video
  6. Danishblunt
    I've never used an oven to do this, always used a heatgun instead. So i'd say you should do it like this:
    - Preheat oven to 200c
    - Clean you card with isopropylalcohol
    - make small aluminium balls with aluminium foil like this:
    - Put card into 200c oven for around 7 minutes
    - Take out the card
    - Let it cool down for 20-30mins
    - Check if it works on notebook.
    Post your results here on the forums.
  7. bennyg
    bennyg Notebook Deity
    OP please remove GPU board and try to power on
    Plus, what GPU?
  8. Ignaciotro
    Ok, i'll try this and post here. Thanks a lot
  9. Ignaciotro
    Is a Nvidia Gforce GTX670m 1,5gb
  10. Ignaciotro
    removing the graphics card does exactly the same as with it.
    I will do what indicated Danishblunt next week and I will tell you if there has been luck
