Help on Wireless Home Networking
Discussion in 'Windows OS and Software' started by red_chief, Jul 4, 2004.
  1. red_chief
    red_chief Notebook Consultant
    Setup: Both on Windows XP Professional
    Laptop: Earthlink dial-up with wireless LAN Proxim a/b/g combocard
    Desktop: AOL Cable modem with wireless router D-link DI-614+
    I establish a connection with my laptop and can transfer files already. Have excellent signal. My problem is I cannot browse the internet on my laptop using internet explorer. What steps I need to do to make it work???
    Please help...
  2. Quikster
    Quikster Notebook Deity NBR Reviewer
    first thing you may want to try is mac cloning, so that the router can't tell the difference between your router and the last computer you had hooked up.
    Also, it may have special settings set on your last computer that you need to program into the router. If none of this helps I would suggest calling dlink.
    zx5000 :: 2.4M :: 512 DDR :: 40gb 4200 RPM HD :: 15.4" :: Radeon 9600 Mobilty M10 :: Aquamark3 22,856
  3. red_chief
    Thanks quikster for your reply.
    How do I do mac cloning[?][?][?]
  4. Quikster
    on my dlink 624 its on the first page under wan, there is a clone mac button.
