Help needed
Discussion in 'Windows OS and Software' started by LogantheHamster, Jun 19, 2018.
  1. LogantheHamster
    LogantheHamster Notebook Enthusiast
    Hi guys,
    since the latest Windows Update to version 1803 I believe my Windows master boot record is somewhat broken, because it doesn't automatically boot from any bootable SSD anymore, but from every other medium. However when I set my PC in sleep it does boot from bootable SSDs, which is kind of strange.
    When I start my PC I currently have to enter the boot menu and chose the SSD on what my Windows 10 is installed on, to boot from - quite annoying.
    So far I've done the most common solutions you can find on the net, but reinstall, reset or similar my Windows 10 installation. I checked my mainboard and other hardware too, the tools I used detected not a single issue. I simply do not want to set it up completly again. ^^
    Hopefully you can help me with this and find a solution.
    My system is as follows:
    - Intel Core i7 4770k
    - ASRock Z87 Extreme6/ac
    - 16,0GB Dual-Channel DDR3 @ 1600MHz (10-12-12-31) by Team
    - 2x Nvidia GTX 970 by ASUStek
    - Windows 10 Pro 64-bit
    Greetings,
    Logan
  2. Aivxtla
    Aivxtla Notebook Evangelist
    Try this if you are using UEFI/GPT
    http://www.dell.com/support/article...windows-7-8-81-and-10-on-your-dell-pc?lang=en
    Try this if you are actually using MBR
    You get to the below option either via rapid F8 clicking as your computer starts or multiple failed boots taking you to recovery options or via system settings in Windows if your are able to reach windows desktop.
    Go to Startup Repair -> Command prompt
    type this: bootrec.exe /fixmbr
    To know if you are using GPT or MBR go to Disk Managment in Control Panel and right click the target volume and click its properties.
    LogantheHamster likes this.
  3. StormJumper
    StormJumper Notebook Virtuoso
    It sounds more like a board issue not a Windows O/S issue. Did you check your BIOS update as it seems like your BIOS is failing is what it sounds like also if it has battery you need to check the battery condition.
  4. LogantheHamster
    Thanks for the reply, did not help though.
    Hi, Bios is up to date and battery is still in the green.
    I'll reset the PC tomorrow and see if it fixes the issue, if not I let Windows reinstall itself and if this doesn't work I'll do a clean install.
