Help needed: Sony Vaio Z21 shuts down after 10 seconds
Discussion in 'VAIO / Sony' started by martinez9049, Feb 8, 2018.
  1. martinez9049
    martinez9049 Newbie
    Hey guys,
    I took my Z21 out of retirement and have been using it for a couple days without issue. I was using it today and everything was good until all of a sudden the laptop turned off. I restarted it and got to the windows login screen and it turns off. I did this exercise a couple times with the same result. To see if it was a windows issue, I booted into the bios setup screen and let it sit, and after about 15 seconds it turned off. It turns on right away every time. I've tried with the battery removed and only connected to ac power with the same result. I'm scratching my head on this one...I thought maybe the cpu's were overheating but I can feel the fans come on when the laptop is on. When it does get to the windows login screen there are no errors on the way there. If I'm quick enough I can type my password in and the desktop starts to load up before shutting down.
    Any ideas?
    Thanks
  2. galaxyge
    galaxyge Notebook Consultant
    Well only thing I can say is the obvious.. must be some hardware issue.. probably time to open it and check the connectors and soldering points. If it’s worse, some transistor or similar component might be failing, but I’m not an expert here.
    Sent from my iPad using Tapatalk
  3. PommieD
    PommieD Notebook Geek
    You need to test and eliminate things like the memory, hard drive/s etc, you need to pull it apart, check all the connections especially the graphics connector, you should try it with an external screen and replace the thermal grease on the cpu and graphics card unless they are soldered, set the bios to default and try again. If you've never worked on laptops, find out as much about taking them apart as you can, it's easy to cross thread screws and break the plastic connectors if you don't know what your doing.
    My advice, don't rush take your time and take photo's with your mobile as you take it apart.
  4. daibatzu
    daibatzu Notebook Guru
    It is possible your fan is not coming on and needs replacing. unbolt the laptop, turn it on, and see if the fan kicks in. If it doesn't, it needs replacing
  5. galaxyge
    Oh and yes, but even if the fan kicks in, your laptop might be overheating.. the thermal paste may be disfunct and needing to be replaced.
    Check if hot air comes out of the fan vents. If not, look for the thread explaining how to replace the thermal paste.
    anytimer likes this.
