Help needed please for hot slow CF-19, Mk6
Discussion in 'Panasonic' started by Liteace, Jun 25, 2018.
  1. Liteace
    Liteace Notebook Consultant
    Hello All, hope your all well. I need a little help with my Mk6, over the last few weeks it seems to have slowed and is getting hot on the right hand side of the palmrest.
    I dont know if its slowed because it hot and its throttling back to save it getting hotter or its got another problem.
    Its used to be lightning fast as its fitted with 8gb and a SSD but now when I click on an icon its taking a good 30 - 45 sec's before the program opens and when open it runs slow
    What can I check please
    Thanks
  2. User32
    User32 Notebook Evangelist
    Take it apart and replace pads, and reinstall I guess?
  3. Liteace
    Thanks, that wouldnt be easy for me, I'd need step by step for that.
    Ive just looked and at idle its using 49% CPU and 55% physical mem, is that to much at idle ?
    Thanks
  4. User32
    Yes it is, you're supposed to hover around 0% CPU use in idle.
  5. Liteace
    Ive just checked my Mk4, its basically the same setup, 8Gb with SDD and at idle 0% CPU and 29% physical mem, could that be the problem, where would I look to see whats eating the CPU on the Mk6 ?
  6. User32
    Task Manager > sort by CPU usage
  7. Shawn
    Download a live linux iso. Burn to usb and try it.
  8. jonlowe
    jonlowe Notebook Consultant
    What version of Windows are you running? I know XP has an issue where the updater can tie up 50% CPU, essentially one complete core on a 2 core processor.
    Have you run Malwarebytes and/or KVRT? Maybe a virus or Trojan, or Bitcoin miner got on it somehow.
  9. Liteace
    Im running w7 on both, Im just running a scan now, its not even a 3rd of the way through and its says there's 191 infected files, i'll have to wait till the end to see if they're ALL bad files or the AV has picked up loads that are not.
    It only goes on the internet for updates so no idea where all the infected files have come from
    Ive got the bottom of with a 3 inch fan cooling it as its on charge as well
  10. User32
    Time for a format and reinstall.
