help needed: how to determine if GPU is dying?
Discussion in 'Gaming (Software and Graphics Cards)' started by bwolmarans, Jan 6, 2019.
  1. pete962
    pete962 Notebook Evangelist
    I would ask : did you crash because of your undervolt or whatever the settings you were changing with XTU, or was it just simple fact of running XTU in the background, cause you the problem? Because normally XTU will reset all settings to original after the crash and it will be the very first thing to look at, to find a cause of crash, but sometimes I had issues even if XTU was just running in the background with stock settings. Also, keep in mind XTU has a driver that loads on bootup, regardless if XTU itself is ever run. You need stop the driver from loading in task manager or remove XTU altogether.
  2. bwolmarans
    bwolmarans Notebook Consultant
    Hi sorry for late reply, I think it was just because XTU was running in the background. It's pretty stable now because xtu no longer runs and "command and control" no longer runs, uninstalled both. - I have had one crash in last 20 or 30 overwatch sessions see log below ( short log this time! ) but not like every 3rd time playing like what was happening before, so removing xtu has made it almost totally better. Here is latest hwinfo64 sensors log with ALL sensors on, there was a full system crash while playing overwatch near the end of this, had to cold boot to fix it, here is the short log file: https://docs.google.com/spreadsheets/d/19rXfjX6hL8BpivtYI9p1gJ0yevdOEYfb0ovPqjz3YoI/edit?usp=sharing
  3. TR2N
    TR2N Notebook Deity
    So it was software related not hardware.
    Moral of the story?
    Tl: /DR Always remove rogue software before testing.
  4. pete962
    Who would have thought XTU from Intel would crash the system even on stock settings. I had few unexpected shutdowns and at first I didn't believe it was caused by xtu itself, I even double checked the voltage settings, thinking, maybe I forgot and somehow set it too low, but it was just running in the background at stock and since I removed it, all is fine. I also had issues with speedfan. Bottom line is, with so many different hardware combinations it's almost impossible for software makers to test every configuration and pretty much any program can be a suspect and no, I would not consider XTU as rogue.
    So I would say moral of the story is: don't assume anything and run your system as lean as possible. BTW on my system Throttlestop works much better than XTU.
  5. Gumwars
    Gumwars Notebook Guru
    I believe Aorus has made mention (or I've read elsewhere) that XTU and C&C don't play well together. C&C has overclocking utilities that can create problems being layered on top of XTU. Additionally, and this is from my own experience, I'm not impressed with quality control at Gigabyte/Aorus. Because you had that one crash even after uninstalling XTU/C&C, I'm not convinced this is entirely a software issue.
    After getting rid of my X5V7, the alienware that replaced it has been crash free for more than a year. My G75VX before it has never crashed in the 7 years I've owned it (still chooching, its my kid's rig now).
    bwolmarans likes this.
  6. bwolmarans
    update: spent $55 and got a big heavy 230W power supply brick. Now my kill-a-watt shows up to 225 watts being drawn when playing overwatch. so far no crashes. will keep testing. but if the laptop is sucking 225W, then the 200W power supply that shipped with the laptop would certainly not have delivered the required power. Based on the original diagnosis by some nice person to my first couple of posts, that certainly seems like the right direction to go in, so I'll keep testing and if I have any more crashes I will reply here, if I don't, it means there was simply not enough power.
    slight edit: I wonder why then I was able to play for years without issue? Is my laptop now drawing more power than it previously did? if so why? I am not running xtu service. could there be some kind of residual setting from when XTU was running that is stuck in the system, causing more power draw?
