Help needed for bad company 2!!
Discussion in 'Gaming (Software and Graphics Cards)' started by Ulags, Jun 7, 2011.
  1. Ulags
    Ulags Notebook Consultant
    I just bought the digital version of bfbc2 from amazon.com, i installed it and was all set to play. But then, when i ran the exe file, bang! I got this error. 'there is a problem connecting to the server. Please check your internet connection is active or else try again later'. I cant even get inside the game. Am frustrated. Please help me. Wanna play this game very badly ;-(
  2. Syberia
    Syberia Notebook Deity
    Sounds to me like a perfect example of DRM screwing over a paying customer. Just wait 'til EA pulls the plug on all copies of BC2 the moment BF3 hits the shelves.
  3. ronnieb
    ronnieb Representing the Canucks
    Check your firewall and make sure the ports are opened/the application is allowed
  4. Ulags
    I have done the following but still same result- updated windows, updated video drivers, updated the game, switched off firewall, uninstalled antivirus, reinstalled game, tried both wifi and internet lan connections, still same result.. Am going mad at this game.. Please do someone have a fix? I just need to play the multiplayer.. Help nbr members.. ;-(
  5. DEagleson
    DEagleson Gamer extraordinaire
    You could try registering the key on Origin, EAs digital store and try again.
    They install the very latest client so no need to patch it up later.
    If that fails its probably a ISP issue.
  6. djboz
    djboz Notebook Consultant
    Is this just when you are trying the multiplayer aspect of the game? Is it Punk Buster that is displaying the message? I had issues when I first installed BC2 due to Punk Buster. It needs manually updating (if memory servers me correctly). Just google it (cant give you a direct link to anything at the moment, at work, and we have a nasty firewall :-/) and see if that works (google "manually update punk buster" for results)
  7. Ulags
    Hey guys thanks for the replies. I cant even get into the game, i run the exe file and then this error pops out.. I cant even get into the game menu.. ;-(
  8. DEagleson
    Maybe the version off Amazon is corrupted?
    Did you try installing it off Origin?
  9. Ulags
    am gonna use a crack.. F*ck EA and its DRM
  10. Kingpinzero
    Kingpinzero ROUND ONE,FIGHT! You Win!
    Try to manually update punkbuster mate. It solved a similar problem.
    Also if you're behind a router, put your pc under DMZ.
