Help needed: 8740w + GTX 1070
Discussion in 'HP' started by triturbo, Apr 3, 2018.
  1. triturbo
    I've got recently a Zotac 1070. I've used an external display (DP) to install it, but the internal screen (eDP) is not recognized at all. Any input would be appreciated. Thanks.
    @ChanceJackson @Prema
  2. ChanceJackson
    ChanceJackson Notebook Evangelist
    did you flash it to the MSI bios yet? I believe your laptop mobo id is 1520 correct? were there any lines in the unmodified nvbli.inf regarding the 1520?
  3. triturbo
    Not yet, stock Zotac. Should I?
    Nope, none at all. Should I download the latest driver that was intended for my machine? If yes, the 1070 wasn't available back then.
  4. ChanceJackson
    I suggest flashing to the msi 1070 mxm vbios and seeing if that will recognize the internal screen after reboot, the zotac vBios was never intended for use with eDP and likely lacks that info
    if that doesn't work download the latest nvidia driver HP has for your machine and explore the nvbli.inf for all references to your machine 1520 chances are all official video card configuration use the same Section ID # investigate that section ID and make sure the same installer options in the Section ID you use in your modified INF mirrors what was in the official inf.
    I have some vBioses in http://forum.notebookreview.com/thr...a-g1-zbook-15-but-its-not-perfect-yet.803964/
    *Fair warning my laptop is Optimus capable and that is how i use my 1070n i wasn't able to get it to display to my internal screen with Hybrid Graphics off
  5. triturbo
    How was the msi vBIOS working for you?
  6. ChanceJackson
    It was fine except it drew more power @Striker1234 was able to to get his zotac card to display on the internal screen of his eDP dell using the msi vbios
    triturbo likes this.
  7. triturbo
    What version of NVFlash you've used? I've tried to no avail both Windows and DOS versions. The DOS ones say that they can't recognize the GPU. The Windows versions all list the Read Me file no matter which key I press, only Q works, but that's to quit.
  8. ChanceJackson
    hmm I t was a while ago but I used the windows version of nvflash from an elevated(Admin) command prompt
  9. triturbo
    Elevated CMD is what I'm using as well. Can you check, or send me the version that you have used? Thanks!
  10. aaronne
    aaronne Notebook Evangelist
    triturbo and ChanceJackson like this.
