HELP! MSI GT72 power issues
Discussion in 'MSI' started by Yan92, Oct 9, 2020.
  1. johnbb
    johnbb Notebook Consultant
    Good job mate!
  2. panzer06
    panzer06 His Imperial Majesty
    Interesting. I had this same issue with the AC Adapter shutting off during game play and the light on the AC Adapter turning off. Connected my Alienware AC Adapter and it worked fine.
    Ordered a replacement AC Adapter.
  3. hacktrix2006
    The problem issue the symptoms for both an AC issue and a Short are the same.
    I had the same issue with my old MS-16F2 where I thought it was the AC adaptor but it was the GPU that failed.
    Sent from my SNE-LX1 using Tapatalk
  4. tim0thy001
    tim0thy001 Newbie
    Hi, i like every one else have power brick turning off and seems to be GPU related and want to give a try to changing the MOSFET, as i understand there are 3 (but can add upto 6total, is there any benifit for this) do you know what the model info for the MOSFET that i need to order?
    I also see one member said you could upgrade to 10 series could some one post a link to 10 series GPU that would fit in my gt72 dominator pro should changing my MOSFET go wrong (amazon US or ali express)?
  5. johnbb
  6. tim0thy001
    tim0thy001 Newbie
    Thanks, I tried to order the MOSFET and apparently they have been discontinued so my order was cancelled I also don't see my self spending that much getting a 1060 or 70 as I'd rather put that towards a new card.
  7. tim0thy001
    tim0thy001 Newbie
    So managed to find s few places to buy it can you confirm which of these are correct
    https://www.digipart.com/part/csd87...FYs8i1JK36XRC6M13aIZcM-fJcqE1m9hoCMoUQAvD_BwE
    Thanks in advanced
  8. johnbb
  9. tim0thy001
    tim0thy001 Newbie
    I went ahead and ordered I had the same model number as the previous guy just the lower numbers were different but it's the same 980 card so assume it's the same.
    Model: 87350D was written on it. Any way the laptop in its current state is very useless in happy to take a chance
  10. johnbb
    as long as the first numbers are the same, the other ones are usually the manufacturing date
