Help me turn off the annoying webcam blue light
Discussion in 'Dell' started by cell323, Apr 8, 2008.
  1. cell323
    cell323 Notebook Consultant
    Any help appreciated thanks.
  2. David
    David NBR Random Reviewer NBR Reviewer
    uninstall the webcam driver?
  3. cell323
    that will render the webcam unusable...
  4. David
    that's true..:p
    Is the light always on or only when you activate the webcam?
  5. mudkiller
    mudkiller Notebook Enthusiast
    Black tape?
  6. cell323
    when i activate it.
  7. cell323
    Black tape? I'd like a technical answer, not a mickey mouse answer. thanks
  8. David
    Well, the thing that control when the light comes on is really the driver. If you know how to recode your current driver, you can bypass the light activating when your webcam is on. Other than that, you don't have much options.
  9. cell323
    :err: .........
  10. DirkBelig
    DirkBelig Notebook Guru
    Why do you want to disable the LED? A spot of black tape will do it as will a drop of paint, but as far as a setting goes, I doubt there's an easy fix.
