Help me to decide
Discussion in 'What Notebook Should I Buy?' started by ScooF, Sep 9, 2017.
What you suggest
  1. First
    0 vote(s)
    0.0%
  2. Second
    0 vote(s)
    0.0%
  3. Third
    0 vote(s)
    0.0%
  4. Fourth
    1 vote(s)
    100.0%
  1. ScooF
    ScooF Newbie
    Hi guys
    im willing to buy a new laptop
    but i have a lot of options right now
    First acer-gx-791-71 ($1600 usd)
    i7 6700HQ
    980 8GB VRAM "This is desktop version NOT THE MOBILE ONE (980M)"
    16 gb ram ddr4
    256 ssd + 1 tb hdd
    you can check it here:
    http://snlookup.com/acer-predator-gx-791-notebook-nh-q12em-001/#ffs-tabbed-14
    Second one acer g9-793-79v5 ($1750 usd)
    i7 7700HQ
    1070 8GB
    16 gb ddr4
    256 ssd + 1 tb hdd
    https://www.amazon.com/Acer-Predato...01N6S4A2U/ref=cm_cr_arp_d_product_top?ie=UTF8
    Third asus rog strix GL702VS-DS74 ($1940 usd)
    i7 7700HQ
    1070GB
    16 gb ddr4
    512 ssd + 1 tb hdd
    the screen is 120hz
    (Note: some reviews point that the CPU temp can go to 97c while gaming)
    https://www.amazon.com/dp/B01N6KLBR1/_encoding=UTF8?coliid=I3AH7SAK22K1U1&colid=LXGDBPAFT77S
    Fourth ASUS ROG G752VS-XB72K "(Certified Refurbished)" ($1500)
    i7 6820HK
    1070 8gb
    32 gb ddr4
    256 ssd + 1 tb hdd
    (Note: some reviews point that the CPU temp can go to 95c while gaming)
    https://www.amazon.com/dp/B071KCV9S5/_encoding=UTF8?coliid=I3JZXIIYH4Z0U2&colid=LXGDBPAFT77S
    all of these laptops have G-sync
    and im gonna use it as a desktop for about 4-5 years
    so which one you suggest ? i play alot and also record my games
    The first laptop is from local store and it comes with 2 years warranty
  2. Danishblunt
    Danishblunt Notebook Deity
    In that pricerange you can do better. Where do you live? USA?
  3. ScooF
    ScooF Newbie
    nah
    i live in middle east
  4. Danishblunt
  5. ZaZ
    Then why not get a desktop, which will offer you better bang for your buck and be easier to fix should a problem arise.
    Jarhead likes this.
  6. Danishblunt
    Wow I actually didn't see that ;_;
    If you're going to use it as a desktop anyways, then you should do as ZaZ said, it's actually way more efficient and you'll get a lot more performance.
  7. ZaZ
    That's why I get the big bucks.
  8. ScooF
    ScooF Newbie
    i already have one
    but lately im travelling a lot of time and it is painful to move a desktop
