HELP! m17 gpu fan not working
Discussion in 'Alienware' started by nandeep, Apr 17, 2009.
  1. nandeep
    nandeep Notebook Enthusiast
    hi guys
    I have cleaned my m17 with compressed air, now my gpu fan doesn't run.I have contacted alienware, they want me to send my system (they refuse to ship me the heat sink.....:eek: lol) 12 business days is long period and I'm ready to loose my warranty for that . Can someone tell me if i can buy the gpu heat sink elsewhere.:confused:
    thank you
  2. whizzo
    whizzo Notebook Prophet
    for starters, open your rig up and make sure the fan cables are still plugged in. then, remove the fan from your system (aren't the heatsinks and the fans separate?) and carefully try to get the fan to run with an external battery just make sure you know which connectors are for the power, and which for regulating the fan speed.
  3. The_Moo™
    The_Moo™ Here we go again.....
    yes they are seperate in our system i have looked around alot in there lol
    really thats stupid and you can proably find a new fan on ebay and use it.....they would never even look
    i have seen direct blast of canned air unbalance a fan and make it grind and srew it up pretty bad but never kill it lol
  4. nandeep
    the cables are fine, m17 has the fan attached to the heat sink. and testing it with external power is not possible as it has three wires going in.
  5. The_Moo™
    yes you can one is power one is ground ....if it runs off power its got a +,- lol
    should be red and black wires and a white one
  6. nandeep
    tried with 6v dc but no use.........
  7. whizzo
    shouldn't one be red, one black, and one yellow? of of those is for the fan speed, the others for power.
  8. ryujin
    ryujin 2B or not 2B
    i would gander:
    red = +
    blk = -
    ylw = speed
    just a guess from previous electronics uses. but there is no set standards for these type of items.
  9. The_Moo™
    put more volts !!!!!!!! lol jp
  10. nandeep
    9v......12v.......no good, doesn't work
