Help installing unlocked a10 bios for m18x r2
Discussion in 'Alienware 18 and M18x' started by sverri, Aug 29, 2018.
  1. sverri
    sverri Notebook Enthusiast
    Rengsey R. H. Jr. likes this.
  2. Mastermind5200
    The guide is written out right there on the post
  3. Rengsey R. H. Jr.
    1) Make a bootable USB Stick
    2) Copy all the files from the Zip file ( unlocked bios and flashing .exe files ) to the USB stick
    3) If you are on Legacy boot , you can hit F12 and boot off the USB Stick. Execute the PRR2 exe to unlock bios , then flash unlocked bios, restart
    3A) if you are on Windows 10 with UEFI Boot , go into BIOS and change the boot to legacy boot , restart and F12 to boot off the the USB Stick , execute the PRR2.exe to unlock bios , then flash unlocked bios. When done, don't forget to go back into bios and change the BIOS back to UEFI Boot so windows can start.
  4. sverri
  5. sverri
  6. Homer S
    Homer S Notebook Consultant
  7. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    if you do not know how to make a bootable USB drive, you definitely should not be playing around with BIOS flashing or unlocked BIOS settings....
  8. sverri
    Thanks for the vote of confidence guys. I did in the end manage to get a usb boot working through the rufus program which no one recommended as the cmd windows way didnt work for me, and i now have unlocked bios☺
