Help installing SanDisk Extreme in XPS L702x
Discussion in 'Dell XPS and Studio XPS' started by hectormuniz20, Mar 22, 2012.
  1. hectormuniz20
    hectormuniz20 Notebook Enthusiast
    Hello all
    I got a new Sandisk Extreme 120gb ssd, I decided to do a clean win7 pro 64bit installation, it took more than an hour to install win7 and when windows finally booted up, my laptop was freezing up randomly and when installing drivers and had to reboot the laptop, sometime it won't reboot. I decided to install back the two 500gb hd and now windows does not want to boot up, a line stay blinking on the upper rigth side of the screen. Now I put back the ssd and just keep getting error message that there were I/O problem with my ssd. I have the A14 bios version. Can someone help me out with this? Thanks
  2. hectormuniz20
    Any idea someone? I'm formatting and installing windows 7 again on my ssd, and now I'm having problems with this installation. I'm so frustrated, ii is a $1200 laptop, first was the nvidia drivers and all the problems with bios a14 and now this.
  3. pwr1009
    pwr1009 Notebook Enthusiast
    That's really weird... If your warranty is still on I would strongly suggest your to call Dell and ask for a change. Good luck!
  4. hectormuniz20
    do you think they're gonna give me hard time because I did a windows clean installation? or void my warranty?
  5. pwr1009
    Don't worry it's absolutely your right to do a clean install and it doesn't void your warranty for sure.
    If you want to be precocious you can always say that you didn't even start the computer when you receive it but did a clean install right away (which is your right).
  6. Sam_A_1992
    Sam_A_1992 Notebook Deity
    I doubt dell will do anything since the problem seems with the ssd. OP Have you simply tried reinstalling windows on the ssd with JUST that drive in the machine, make sure to take the 500gb drive out before you do this and see if it works if not tell me the problems exactly how they are. Dont try to install any drivers, just do this and then see. It could be the firmware on the ssd needs updating which can cause freezes etc.
  7. madmattd
    madmattd Notebook Deity
    What Sam said. Make sure neither of the original drives are in the machine when you try to install the the SSD. Since boot files are placed on the old drives from the initial factory install, it can cause all kinds of issues to have them in when doing the new install.
    Dell won't help out with issues on a drive you bought and installed. But on their supplied drives, they cannot deny you service for re-installing the same OS that came with the system. Despite what they might try to tell you. Been there with them on that before...(when I said I reformatted immediately, they couldn't understand why. According to them they install ZERO bloatware, apparently having 95 processes running on an out-of-the-box machine is normal... :rolleyes: )
  8. hectormuniz20
    Well, I just put back both 500gb hd and since I have a server running Windows Home server, before I formatted the hd the first day, I created a backup image. My dell xps can't find the server ( i think is lan card drivers) so i put one of the 500 hd in my hp and re-image with the image I created the first the when I got the new dell laptop. I put the 500gb hd back to the dell and now I'm running windows home premium with all the bloatware that came with the dell laptop. I think I'm going to shrink the 500gb hd create an image and the put that image on the sandisk sdd.
    I'm not very confident that is going to fix the problem, with the ssd it took 5 minutes to boot up windows 7 pro, way too slow. It could be a bad sdd.
    Thanks for the response guy, appreciate it.
  9. hectormuniz20
    I've been searching around for a new firmware but it seems there is not such of thing.
  10. hectormuniz20
    I just tried to shrink the C drive to something close to 115gb but Windows won't let me shrink it to less than 245gb, if a create an image of the size it won't fit on the sandisk 120gb ssd
