Help, how to show fps infor in counter strike source
Discussion in 'Gaming (Software and Graphics Cards)' started by mikezhengcc, Feb 7, 2007.
  1. mikezhengcc
    mikezhengcc Notebook Enthusiast
    anyone know?
  2. Sliced_Bread
    Sliced_Bread Notebook Consultant
    go into console and type
    net_graph 1; net_graphpos 2
    Or download FRAPS and turn it on before you enter a game.
  3. mikezhengcc
    Sorry, how to get into console? or what is console?
  4. RedSensiStar
    RedSensiStar Notebook Deity
    ************** filler
  5. mikezhengcc
    ok, thanks Star. so where can i get that? Better yet, can anyone direct me a site or show me step by step process. Thanx!
  6. iPPi
    iPPi Notebook Consultant
    In game, hit the ~ key.
    If that does not bring up the console, go into the options, and, I think it's in the control or game settings, there's a checkbox to enable console window.
    Then, hitting the ~ key in game will open the console window.
    Now you can type console commands. Use the command above to get the framerate command.
    Alternatively, type 'cl_showfps 1' without the quotes to get another fps reading.
  7. Sliced_Bread
    I think you have to go into options, then controls/keyboard whatever it is and there should be an "advanced options" button. Click on that then enable your console.
  8. mikezhengcc
    thanx iPPi and Bread! just one more question. How do i disable it later on?
  9. RedSensiStar
    type it again and set to 1/or 0
