[Help] GTX 285m sli drivers...
Discussion in 'Alienware 17 and M17x' started by mala31, Jul 12, 2012.
  1. mala31
    mala31 Newbie
    Hi,
    I have a problem with my notebook :
    I know there is actually no official support for my graphic card, but i know there is some modded inf in order to force the installation of newer drivers. (i have actually the lastest official dell driver)
    Where can i find lastest drivers with modified inf ? i've found in laptopvideo2go a driver 302.59 with modified inf (GTX 285m is in the list) and i can't install it manually.
    I'm sorry if there is already a thread but i've found nothing with the search, and finally i'm sorry for my english cause i'm a little french and i don't love google trad...
    Thanks
  2. GabeZ
    GabeZ Information Technology
    Some people have found success in using the inf file from a driver that will install and using it for you modified driver.
    Good Luck,
    Gabe
  3. SlateJones
    SlateJones Notebook Geek
  4. mala31
    mala31 Newbie
    Oh, thanks for the link, i'll try tommorow =)
  5. mala31
    mala31 Newbie
    It works great, no more bsod but always very high temp. (about 95°C ingame)
  6. SlateJones
    mala, if you havent cleaned out your laptop in a while, give the vents and fans a good cleaning. That will help. But I will tell you that I also get higher temps with these drivers. With the 290 series drivers my temps would get up around 75-79 and as soon as i installed the 300 series my temps now can get as high as 95.. So it is semi normal with these drivers, I dont like the higher temps, and I have a u3 note cooler. Its either these drivers overvolt the cards slightly or the temps are being mis-read by the card with this driver. But I havent had any problems with them other than the temps.
