HELP: Gaming Laptop — feedback appreciated?
Discussion in 'What Notebook Should I Buy?' started by LaMOi, Jan 20, 2021.
  1. LaMOi
    LaMOi Notebook Guru
    Hi...
    Relatively noobish when it comes to modern PC gaming.
    I migrated exclusively to consoles mid 2000s. Got fed up with my PC, constant tweaking to get games to run, upgrading etc.
    Unfortunately consoles don’t really get many RTS games which were some of my favourite type of games, I do miss them.
    So I’m looking to buy a gaming laptop. The reason not a desktop PC being due to living in a flat currently (no room) and have small children.
    Laptops are more limited with regard to upgradability — but for the moment it’s far more practical.
    — To be clear, I’m not looking to be mobile with the laptop, I will use it at home, predominantly plugged in as a Desktop replacement. So battery life is not such a big deal.
    — My budget is around £1000-1500.
    — Buying in the UK.
    Ultimately I’m willing to spend a bit more if it will get me a laptop that has some decent longevity. One that is powerful enough it will last me a good number of years without quickly becoming obsolete with regard to playing the latest games.
    I will predominately be using it to play RTS games, but may play other things and would like at least the option to play AAA games.
    Although I will likely get a PS5 at some point for those.
    So games like,
    Total War series
    CoH1&2
    MoW Assault Squad 2
    Bannerlord
    State of Decay 2
    Currently looking at Amazon.
    https://www.amazon.co.uk/gp/aw/d/B0877M83X3/ref=ox_sc_saved_image_2?smid=A3P5ROKL5A1OLE&psc=1
    HP OMEN 15-dh1010na 15.6 Inch Full HD, 144 Hz Gaming Laptop, Intel Core i7-10750H, 16 GB RAM, 1TB SSD, NVIDIA GeForce RTX 2070 with Max-Q design (8 GB Dedicated) Graphics, Windows 10 Home
    So far it’s the best deal I’ve seen with regard to components and price.
    TOTAL WAR 2
    RECOMMENDED SPEC:
    OS: Windows 7 / 8 (8.1)/ 10 64Bit
    Processor: Intel® Core™ i5-4570 3.20GHz
    Memory: 8 GB RAM
    Graphics: NVIDIA GeForce GTX 770 4GB | AMD Radeon R9 290X 4GB @1080p
    DirectX: Version 11
    Storage: 60 GB available space
    It all seems ok.
    But ideally I would like to run games like Warhammer Total War 2 smoothly (60fps?) with everything on Ultra settings...
    Also — any advice on where to buy from?
    Amazon are pretty reasonable price wise and my shopping experience over the years has been pretty good. Even returns on expensive items, given refunds with very little fuss (my wife recently returned an Apple Watch as she didn’t like the colour!).
    But a laptop is a little bit more money.
    Is it better to buy direct from the Manafacturer? HP? But it is more expensive.
    OR are there reputable sites that offer to build custom laptops?
    I am also somewhat confused about AMD vs Intel chips. AMD seems to outperform Intel and is cheaper?? So what’s the catch?
    Lastly — I am reading that a new wave of next gen laptops are due to be coming out soon (ish?) — should I wait? Will it dramatically change pricing on the mid tier to premium laptops??
    Any advice would be much appreciated, as I really don’t want to drop a large sum of money on something that will disappoint.
  2. LaMOi
    LaMOi Notebook Guru
    Also — as mentioned previously.
    if these are right around the corner...
    MSI GP76 Leopard Core i7 16GB 1TB SSD RTX 3070 17.3" Win10 Home Gaming Laptop
    Currently pre-order price is £1799.
    that’s a couple of hundred more for a quite dramatic upgrade.
    also —
    ALIENWARE AURORA RYZEN EDITION
    £2,049.00
    £2,068.99
    Save £19.99
    Includes VAT
    Free Delivery
    AMD Ryzen™ 9 3900XT
    Windows 10 Home 64bit
    16GB Dual Channel HyperX™ FURY DDR4 XMP at 2933MHz; up to 64GB
    NVIDIA® GeForce RTX™ 3070 8GB GDDR6
    That may ok due to its size... then just get a monitor and a keyboard.
    But still - being able to fold up a laptop and put it away is fairly important at the moment due to space...
  3. LaMOi
    LaMOi Notebook Guru
    Sorry — reformatted my original message.
    1) What is your budget?
    2) What size notebook would you like?
    d. Mainstream; 15" - 16" screen
    e. Desktop Replacement; 17"+ screen​
    3) Which country will you buying this notebook?
    UK
    Don’t mind.​
    I want a new laptop
    Gaming.
    Not really. Just home use.
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    Total War series
    CoH1&2
    MoW Assault Squad 2
    Bannerlord
    State of Decay.
    It’s not a big deal.
    I’m fine with buying online.
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    1080p minimum. 144hz minimum.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Not sure what difference that makes.
    Build Quality and Design
    No. Although I find most gaming laptops are rather gaudy! Not my thing...
    Notebook Components
    15) How much hard drive space do you need?
    At least 1TB SSD
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    Soon.
    17) How long do you expect to use this laptop?
    5 + years
    18) How long could you afford to do without your laptop if it were to fail?
    A week or two. It’s only gaming I guess.
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    If I was guaranteed quality service I would pay extra for good warranty packages.
