HELP - G72GX Double keystroke keyboard problem
Discussion in 'Asus' started by xstahsie, Mar 17, 2010.
  1. xstahsie
    xstahsie Notebook Enthusiast
    I hope someone has a solution to this double keystroke keyboard problem that I am having with mmy (<-- see ) G72GX laptop.
    Here is what I have attempted but all FAILED.
    1. Updated to the latest BIOS.
    2. Restored Win 7 OS to factory using Recovery Disc supplied by ASUS.
    3. Updated the ATK software available on ASUS website.
    4. EXCHANGED the laptop at Best Buy for a new G72GX, But new G72GX has the SAME problem.
    5. Updated all available Windows Update.
    6. Did a clean installed of the retail copy of Win 7 Ultimate on a nnew (<-- see ) hard drive, withouut (<-- see ) any drivers or updates.
    So, as you can see, I have tried many methods of fixing this double keystroke keyboard issue.
    The problem is thaat (<-- see ) it randomly double type keys every few seconds to every 2-3 minutes. VERY ANNOYING.
    Any help from this community would be appreciated. Thank you.
  2. mylowrider
    mylowrider Notebook Consultant
    The problem could be somewhat related to your typing style.
    You can adjust how the keyboard reacts to your input by going to the Control Panel > Ease of Access > Look under Ease of Access Center > Change how keyboard works.
    There you can change different parameters such as "Turn on Filter Keys" to ignore repeated strokes.
  3. ren3g7ade
    ren3g7ade Notebook Evangelist
    maybe you are having a latency issue with your acpi. go to device manager and under Batteries (Battery), disable the acpi compliant control battery method. That might help...
  4. xstahsie
    Turning on the filter keys option w/ avoid repeat keystroke didn't help. Thanks anyways.
  5. ren3g7ade
    did you try disabling the entry i mentioned above for acpi?
  6. xstahsie
    Thanks for trying to help me out. Yeah, I just tried it out and didn't help either. I disabled it in Device Manager, restart the PC, and launch Wordpad and typed away but i'm still getting double keystroke.
    Any other suggestions? Thanks. :(
  7. mylowrider
    You could go to best buy and get another replacement.
  8. xstahsie
    I have thought about it, but in the meantime... is there a solution to this problem?
  9. DCx
    DCx Banned!
    Heh, take your keyboard off, use some doublesided carpet tape and make sure the keyboard stays FIRM to the laptop. The same double-tap problem occurred in many 1000h netbooks, and that was the solution (until asus brought out a bios fix).
  10. ren3g7ade
    Try disabling the ATKGFNEX Service. It is for the hotkeys. It might be interfering with the keyboard as it is polling. It's worth a shot. I saw someone on another forum mention stuttering as a result of it.
